Johnparmenter82
Joined: 11 Sep 2016 Posts: 12 Location: Rochester, new york
Posted: Thu Apr 25, 2019 9:45 am Post subject: It's probably a short but..... |
Porsche 924 1981....just finished putting engine back in....in starter and alternator....battery light is on....I'm going to start tracking wires for a bad ground....but any easy ones you guys could think of would be great _________________ Johnparmenter82 |
Posted: Thu Apr 25, 2019 11:03 am Post subject: |
Ground wire from alternator to block installed and in good shape?
Alternator belt tight? _________________ White 87 924S "Ghost"
Raize
Posted: Fri Apr 26, 2019 12:43 am Post subject: |
| Paul wrote: | Ground wire from alternator to block installed and in good shape?
That thing is a nightmare to get at, it's a horrible design. If it is that, I'd suggest not even trying to fix it and just make a new one.
I made a new alternator earth between the rear cover bolt that's actually accessible and one of the water pump bolts on my engine using some 12AWG and a couple of ring terminals. Works nicely. |
Posted: Fri Apr 26, 2019 3:41 am Post subject: |
I'm thinking the B+ wire is 10mm so the ground wire should be the same or 8 AWG.
4mm 12 awg
6mm 10 awg
10mm 8 awg _________________ White 87 924S "Ghost"
