Raize
Posted: Fri Apr 26, 2019 1:22 am Post subject: Fuel pump wiring questions |
I need to re-wire my fuel pump because there's over a volt of drop between the fuse and the pump and my fuel pump relay is going to burn out if I don't do something soon.
After leaving the auxilliary fuses, what's the route the stock wire takes to the pump?
Where is the earth for the fuel pump located and what's the route the earth wire from the pump takes to get there?
And does anyone know how to remove the "expansion boards" on the relay box (such as the one the fuel pump relay goes in)? |
mr_caarl
Posted: Fri Apr 26, 2019 11:05 pm Post subject: |
I dont know the route of the wires going to the fuel pumps.
The fuel pump(s) are grounded in the luggage compartment near the left rear light. |
