931 timing belt cover hardware?
specialbuild
PostPosted: Mon Apr 15, 2019 11:49 pm    Post subject: 931 timing belt cover hardware? Reply with quote
I acquired an '80 924 Turbo recently and I'm trying to straighten out a few issues, one of which is it's lack of a timing belt cover.
I have the cover but none of the hardware to attach it with. Can someone let me know what all I need to properly secure it to the engine? I want to make sure I get the correct fasteners.
Thanks!
PostPosted: Tue Apr 16, 2019 12:23 am    Post subject: Reply with quote
They are a bitch to remove and reinstall. Probably why its not on the car.
jacobroufa
PostPosted: Tue Apr 16, 2019 12:34 am    Post subject: Reply with quote
From the PET:
You will need 3 each of the following:
* bearing sleeve 056 109 135
* grommet 056 129 669 B
* washer N 011 612 3
* spring washer N 012 226 5
* hex head bolt N 010 218 6
1980 Porsche 931
1981 Porsche 924 Weissach
jacobroufa
PostPosted: Tue Apr 16, 2019 12:37 am    Post subject: Reply with quote
Seconded... Hadn't really thought to say this with my reply, because it's not what the OP asked for, but having just removed mine, I am going to take the tact of a few members of the board and not replace the cover in favor of more frequent belt changes. The belts are inexpensive and the procedure is easy if there's no cover.
1980 Porsche 931
bureau13
PostPosted: Tue Apr 16, 2019 12:42 am    Post subject: Reply with quote
Someone mentioned once that they modified their cover so it was mostly just the part that covered the cam sprocket, so it was easy to get on and off and you could still see/check the belt, etc. At some point I'd like to do that but I haven't yet. Bigger fish to fry...
1986.5 Silver 928S
2007 Hummer H3 (Daily Driver)
Past lives (I miss them all):
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
1987 RX-7 Turbo II (Sold)
1985 RX-7 GSL (Stolen)
