Think these will fit a 931 ?
Goto page Previous  1, 2
PostPosted: Fri Apr 12, 2019 1:17 am    Post subject: Reply with quote
Cedric,
Agreed, I have neg 3.5 on the fronts (seven Cookies) and they fit under the fender lip with no touching and neg .5 on the rears. Raced last weekend and the car was about 1/2 second faster than last fall on the same track.
1979 924 NA race car
1982 924 Turbo almost a PoS
PostPosted: Fri Apr 12, 2019 2:51 am    Post subject: Reply with quote
CÚdric wrote:
Fifty50Plus wrote:
I've been running the 6 inch Cookie Cutters on my race car and they worked fine. Recently the rules allowed me to go to a 7 inch rim. I got a set of 7 inch Cookies and mounted the same tire (Hoosier 205-50-15) on the sevens. The front goes all the way out to the fender well since the extra inch on the seven inch Cookie is to the outside. As for the rears, I had to take the factory spacer out to mount the sevens. Then I found out that the wheel studs were not threaded all the way down. I was able to get a 5 mm spacer for the rear for the wheel nuts to fully seat. The rear tires fit nicely in the wheel well while filling it.
I guess the best looking solution would be 6 inch Cookies on the front and 7 inch on the rear but I really like that extra front track for cornering.
Strange, my studs at the rear are threaded all the way in, ive been running cookie sevens all around for years. Up front is fine on a track oriented car, since you should run maxed out negative camber that will tilt in the wheel significantly. Agree that for a full street car the 6s would fit better. They are light and durable. But if you look at the jap wheels above i think cookies are out of the scope
Get the rear arches rolled and you can refit the 20mm spacer with 15 or 16x7 ET23 rims and 195 50 track tyres. Square front and rear set up best for track grip and balance.
Page 2 of 2
