Joined: 23 Jul 2007 Posts: 1077 Location: The Netherlands
Posted: Mon Mar 25, 2019 5:41 am Post subject: Clutch pedal not fully coming back 931 |
My 931 wasn't used for 4 months. The clutch pedal was on the ground. After a few pumps it came back.
While driving it doesn't come back fully, and the clutch slips a bit.
What could it be, just air in the system, or a leaky cilinder ? _________________ 937 trackday car
Johann
Posted: Mon Mar 25, 2019 6:00 pm Post subject: |
I had this a year or so ago. The slave cylinder was weeping causing the clutch to stay on the floor some times, but if I hooked it with my foot it would pop back up...until it didn’t anymore. After replacing the slave cylinder, I could not get the clutch to come up fully. In the end I found that my master cylinder was also leaking just enough to make it lose pressure. After replacing the master, she is as good as new. |
