K-Roll931
Joined: 08 Jul 2017 Posts: 76 Location: Southfield, MI
Posted: Mon Mar 11, 2019 12:29 pm Post subject: Haste Makes Waste (-_-) |
In my haste to get to setting the timing on my 931, I plugged the wires on the back of my tach wrong/backwards. Even worse, possibly connecting power straight to the ground. And now I've not only got a dead tach (waste), I've got a dead 1980 931 GREEN tach.
Luckily, the wires are fine, I've still got ideal voltage and continuity. But I would rather drive blind than replace it with the regular white gauge face.
Hopefully I've got a replacement lined up tomorrow, or I'm gonna have a helluva time trying to buy an S1 tach and not the whole cluster, or swapping faces with a regular 924 tach.
Don't be like me and try to wire off memory, look at the flow diagram, as frustrating as it can be. Take your time, check as many references as possible, and ask any questions before you proceed. _________________ '80 931 M471 - Dolomite Gray -> Monaco Blue |
Posted: Mon Mar 11, 2019 5:39 pm Post subject: |
Did you find out whats the right way to connect the wires? _________________ https://www.the924.com |
K-Roll931
Posted: Tue Mar 12, 2019 1:16 am Post subject: |
morghen wrote: | Did you find out whats the right way to connect the wires? |
Yes I did, and I'll never forget it now. _________________ '80 931 M471 - Dolomite Gray -> Monaco Blue |
Kenodog
Joined: 25 Jun 2003 Posts: 2645 Location: Vancouver,B.C.
Posted: Tue Mar 12, 2019 2:32 am Post subject: |
Damn brother, that sucks.
Lee _________________ 1979 Euro 931, Olive
1981 931, Sabine
1991 Ford Ranger XLT 4x4
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140 |
Posted: Tue Mar 12, 2019 4:32 am Post subject: |
K-Roll931 wrote: | morghen wrote: | Did you find out whats the right way to connect the wires? |
Yes I did, and I'll never forget it now. |
well spit it out ffs, i'm about to re-install my tach and a friend's tach and i cant see the signs on the plastic bit. _________________ https://www.the924.com |
Kenodog
Posted: Tue Mar 12, 2019 4:43 am Post subject: |
morghen wrote: | K-Roll931 wrote: | morghen wrote: | Did you find out whats the right way to connect the wires? |
well spit it out ffs, i'm about to re-install my tach and a friend's tach and i cant see the signs on the plastic bit. |
1981 931, Sabine
2024 KLX300
2024 KLX140 |
K-Roll931
Posted: Tue Mar 12, 2019 7:34 am Post subject: |
Well heck all ya had to do was ask!
Black goes to 12+, the single green goes to 1, and the brown is ground (-). _________________ '80 931 M471 - Dolomite Gray -> Monaco Blue |
Posted: Tue Mar 12, 2019 6:32 pm Post subject: |
thanks i cant see the plastic markings on mine so i'll just have to take the wiring and position it like you did in the picture, assuming thats the right way _________________ https://www.the924.com |
Posted: Tue Mar 12, 2019 6:47 pm Post subject: |
I got a Sharpie and marked my gauge with wire colours before I removed the wires many years ago. Gauge only been out once since and those markings saved me and the gauge _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
Joined: 29 Jul 2001 Posts: 8794 Location: Royal Oak, MI, USA
Posted: Tue Mar 12, 2019 9:35 pm Post subject: |
Yes, sharpie is the answer... _________________ Vaughan Scott
K-Roll931
Posted: Mon Mar 25, 2019 2:31 pm Post subject: |
Got my "new" tach earlier this week, wired it properly this time, and was finally able to set ignition timing!! Now I have to fiddle with the fuel mixture.... _________________ '80 931 M471 - Dolomite Gray -> Monaco Blue |
