AlexJ
Joined: 07 Mar 2019 Posts: 7 Location: Madeira Island - Portugal
Posted: Thu Mar 07, 2019 6:02 am Post subject: Main crankshaft bearings still an issue - NLA? |
Hi all,
I have noticed through this board reading that over the times to get a main bearing crankshaft set has been difficult (STD) or almost impossible.
Is this issue sorted?
Are they available now?
If anyone knows any source, please inform.
Thanks in advance for any help. |
AlexJ
Posted: Thu Mar 07, 2019 6:10 am Post subject: |
I forgot to say that the car in this case is a 924 Turbo from 81.
I have read so,ethereal that there are two bearing versions for this car.
Internal diameter 60 mm and 64mm.
Earlier cars have 60 mm crank diameter and latter cars have 64mm.
My car’s crankcase has 64 mm crank diameter...
Can anyone confirm this information?
I believe the bearings for the 64 mm are easier to find? |
Joined: 28 Feb 2008 Posts: 1363 Location: Washington DC area
Posted: Thu Mar 07, 2019 8:51 am Post subject: |
Just measured a couple cranks, turbo and NA. Both 64mm mains. I believe only the 76/77 early cars had the 60 mm crank. Either way, first turbos were later cranks (64 mm). BTW turbo and NA cranks are identical except for the location of the input shaft bearing. Totally swapable. _________________ 1979 924 NA race car
1982 924 Turbo almost a PoS
AlexJ
Posted: Thu Mar 07, 2019 10:05 am Post subject: |
Thanks for your explanation !
I have seen many adds at the ebay (glyco sets for example), but they are indicated for engines 85 - up... 2.5 engines and further...
Sorry my ignorance but, do these 2.5 engines have a different crank?
or.. is it the same block???!! |
Joined: 08 Jun 2010 Posts: 1228 Location: Maysville, Colorado
Posted: Thu Mar 07, 2019 10:24 am Post subject: |
Yes, the 2.5 924S motor is a Porsche motor from the 944, a completely different motor. I doubt there are any interchangeable parts. EBS Racing had the last known supply of 924 main bearings. _________________ Mike
'67 MG Midget Dp
Goldwolf
Posted: Thu Mar 07, 2019 10:33 am Post subject: |
I need some, but engine guy can machine the crank and use the oversize, which are easier to get.
I called EBS about 10 days ago and they had a new run being checked for quality, then sending the order to make them. They said about month after the order they would have them.
I need check in on the progress. _________________ 1981 Weissach Edition #179 |
Posted: Thu Mar 07, 2019 11:31 am Post subject: |
They are available in Europe. One of the guys on the 924 owners group in Facebook posted a link to a place that had them. |
Goldwolf
Posted: Thu Mar 07, 2019 1:35 pm Post subject: |
I could find only one link but it doesn't seem helpful. If you can find it please share. _________________ 1981 Weissach Edition #179 |
AlexJ
Posted: Thu Mar 07, 2019 2:39 pm Post subject: |
nickthompson wrote: | They are available in Europe. One of the guys on the 924 owners group in Facebook posted a link to a place that had them. |
Thanks for that!
I have been watching all their posts but couldn’t found it... |
AlexJ
Goldwolf wrote: | I need some, but engine guy can machine the crank and use the oversize, which are easier to get.
I need check in on the progress. |
Alreadycontacted them... 8-12 weeks until they are done... can’t wait that long! |
Posted: Thu Mar 07, 2019 7:52 pm Post subject: |
Limited availability via Karl/colonel @ 924ownersclub in UK or Mittelmotor in DE _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
Posted: Thu Mar 07, 2019 10:54 pm Post subject: |
Goldwolf wrote: | I called EBS about 10 days ago and they had a new run being checked for quality, then sending the order to make them. They said about month after the order they would have them. |
That's wonderful news... I ought to hit them up and get on the list for some... _________________ Vaughan Scott
Kenodog
Posted: Fri Mar 08, 2019 3:57 am Post subject: |
I would wait the 8-10 weeks and get them from EBS. Mittlemotor prices are just zooming around the realm of insane.
Me _________________ 1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140 |
AlexJ
Posted: Fri Mar 08, 2019 11:27 pm Post subject: |
Carrera RSR wrote: | Limited availability via Karl/colonel @ 924ownersclub in UK or Mittelmotor in DE |
Thanks for that but I couldn’t find any of those names on the owners club web page.
Do you have any contact to these people?
Posted: Sat Mar 09, 2019 2:22 am Post subject: |
Ok, I am going to let out a tease...Been holding this one close to my chest for a while now
I have a solution in the works. A solution that should give us bearings for a long time with many size options
Sorry for being so vague but I want to make sure it goes as planned and is tested...I guess now I should accelerate this project too
the teaser pic. Top Left: OEM / Bottom Right: My solution (high quality source)
_________________ 1980 931 since 1989
