The Boost Has Gone Away
Goto page Previous  1, 2
bureau13
PostPosted: Fri Feb 15, 2019 1:30 am    Post subject: Reply with quote
What's the best way to access that with the turbo on the car? Remove the compressor-side intake tubing?
924RACR wrote:
If you can get in there, see if you can turn the compressor wheel by hand...
1986.5 Silver 928S
2007 Hummer H3 (Daily Driver)
Past lives (I miss them all):
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
1987 RX-7 Turbo II (Sold)
1985 RX-7 GSL (Stolen)
CÚdric
PostPosted: Fri Feb 15, 2019 5:01 am    Post subject: Reply with quote
The recirk valve is quit easy to pull out if its housing with the4 screws. It was crushed gasket everywhere when removed the lid.
┤80 924 Turbo
PostPosted: Fri Feb 15, 2019 11:40 pm    Post subject: Reply with quote
Probably...
bureau13
PostPosted: Sun Feb 17, 2019 7:52 am    Post subject: Reply with quote
OK, working on the least intrusive (and admittedly least effort) tests first.
I disconnected the wastegate control line from the top, and tried to pressurize it to see if it would hold. It does not. At all. It's wide open, not a "leak" but my hand vac pump couldn't pressurize it at all. I used an air compressor too, no dice.
What does that tell me? Well, unfortunately I don't know where the leak is. If it's a leak in the hose itself, then that would explain the overboost (although this big a leak would never have allowed the wastegate to open at all, so I think I would not have stopped at 1 bar). Of course, it could have become drastically worse, but it doesn't explain my current zero boost situation. Yes, that could be a different problem, if the overboost and zero boost issues are unrelated.
It could also tend to support my preferred (because it doesn't involve me needing a new turbo) theory, that the wastegate is completely stuck open...I think? In that situation, pressurized air goes where after it forces open the wastegate...out the top port/vent? That's my assumption. This theory involves the wastegate previously being stuck partially open, resulting in slow build of boost followed by overboost to 1 bar, presumably limited by the fact the wastegate was partially open. And now it's broken open entirely.
Sucks that the wastegate is such a pain to get to (no lift here). Might still make sense to remove that cover on the recirc valve on the turbo, just to see what's there. However, I'm wary of causing additional issues, and that wouldn't explain the issue with the wastegate/control line. So maybe since I know there's something wrong there, I just need to take that out and inspect it (and fix it) before moving to the next item...
1986.5 Silver 928S
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
PostPosted: Sun Feb 17, 2019 8:42 am    Post subject: Reply with quote
That sounds very bad as in your WG diaphragm or line is blown wide open..
If the diaphragm in the WG is blown then yes, the pressurized air would go in the bottom port and then out the top port.
If the diaphragm is good and the valve guide is good the air put into the bottom port should go nowhere..
It is possible that the valve guide in the WG is so bad that the air leaks past that and into the exhaust pipes.
Yep it sucks a bit.. It really sucks that diaphragms are like $120 too..
The WG is a 930 WG so they are expencive but are often rebuilt. Plan to replace all of the studs in it..
One good thing is that their is a Tial WG that is a direct bolt on replacement for the 930 WG so if your WG is very screwed up you can just easily replace it with a Tial..
https://www.vividracing.com/tial-f46-46mm-wastegate-for-porsche-911-turbo-7594-p-151577.html
About $480 on Ebay new..
If you go to completely remove the WG line note that it is bolted to the back of the head too on one of the distributor/water housings..
To pull the WG, pull the J-pipe, pull the downpipe/exhaust, pull the WG mount to the torque tube, WG line banjo, WG is off..
Plan to replace the studs/nuts..
Pulling the downpipe will also give you access to the turbine wheel so you can play with it..
I do not think that you can get to the compressor wheel short of removing the compressor housing because of the complicated 931 compressor housing..
If you have the WG off you have the Turbo 1/2 off so that's a bonus..
Cleaning out and replacing the gaskets on the recirc valve is a very good idea.. My original gaskets looked like crushed rock candy.
I replaced mine with hand made leather gaskets..
The recirc valve is extremely simple so you don't have to worry much about screwing it up.. It is just a spring and a piston but possible to put back together backwards so note which direction and end the piston goes in, and spring, and which cap is which and which direction the one with the line goes on gets clocked correctly.
bureau13
PostPosted: Mon Feb 18, 2019 4:14 am    Post subject: Reply with quote
Good info here, thank you. Glad you mentioned about the wastegate line being attached to the head...I'll look for that.
Do you think there is any performance advantage to going with a Tial over rebuilding my stock wastegate (or sourcing a rebuilt 930 wastegate)?
I think while it's out I will add the fitting to the top port for use with some sort of boost controller. May as well...
1986.5 Silver 928S
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
PostPosted: Mon Feb 18, 2019 8:39 am    Post subject: Reply with quote
No..
No performance gain either way I wouldn't think but it might be cost effective..
A brand new tial is about the same price as a used 930 WG that likely needs rebuilt..
930 WG valve guide $100
930 WG diaphragm $150
+ $ for all new studs and nuts
+ $ or time extracting broken broken studs if you aren't super lucky.. I spent a lot of time extracting broken studs.
Then your rebuilt 930 WG is worth good money so is probably a good investment..
But if you can find a good deal on a lightly used tial f46 WG it might be easiest/cheapest..
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/486071-best-wastegate.html
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/782170-wastegate-hammered.html
I think it used to be that replacement valve guides had to be made but now their is one on ebay, and the diaphragms used to be impossible to find but now can be had but quite expensive at $100-$150 so it's a toss up..
If you search ebay for "46 wastegate" Their are a lot of 46mm WGs with 4 bolt flanges but I don't know if the 4 bolt pattern is an exact fit like the Tial..
Some very cheap china ones are available they may fit but who knows how well they might work or not and for how long..
I would definately do that and run a hose from it up top to where you can get at it if/when you ever want to use it..
The top port has some strange metric thread.
Some 931s have a banjo in the top port already for you to put a hose on that makes it real nice and easy.. Some 931 top ports have a mushroom thing that you will have to replace with a barb or banjo to put a line on the top port..
Definately a good "while you are in there" thing to do..
Note that some leakage past the valve guide from the bottom port is acceptable but shouldn't be "wide open"..
A small hand pump might not do it but if your air compressor won't cycle it their is definitely something wrong..
bureau13
PostPosted: Thu Feb 28, 2019 2:47 am    Post subject: Reply with quote
UPDATE
So this is weird...I still haven't been able to get the car up and inspect the wastegate...the 928 is off getting painted so I need this car to stay running...but suddenly yesterday, I had boost. As quickly as it went away, it came back. I don't get it. It's overboosting just as before, btw (which may actually be a previous owner's intent, since the overboost switch is disconnected and the wire to it grounded).
I think the stuck wastegate theory is still possible. Possibly also the stuck recirculating valve in the turbo, although I will blow some compressed air down the boost control line and see if I get different results now.
The one theory that I hope is incompatible with this is the coked-up turbo. Has anyone ever seen one magically start working, like nothing was ever wrong, after failing for this reason?
1986.5 Silver 928S
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
PostPosted: Thu Feb 28, 2019 6:28 am    Post subject: Reply with quote
Sounds like a WWII grenade with a rusty pin..........you know its going to go bang in your hand, but just don't know when
bureau13
PostPosted: Thu Feb 28, 2019 6:45 am    Post subject: Reply with quote
That's a pretty ominous analogy, but, yeah. Pretty much!
1986.5 Silver 928S
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
Page 2 of 2
