another blown starter
jvandyke
PostPosted: Tue Apr 23, 2019 3:39 am    Post subject: another blown starter Reply with quote
Trying to fire up the '87 924s for the spring, blew the nose off the starter, again, this is #3 destroyed. I'm going to try to verify the bell housing isn't from a turbo 944 (they say the starter mounting point is different and matters).
Other causes being investigated.
I'm having a heck of time buying another one. I want an early model "fatty", Pelican and other resources don't differentiate so it's a crap shoot what your gunna get I guess. this is my kid's car and he has to sell it off for tuition money so I don't want to go high end, gear reduction, torque monster, which is what I would do if it were mine. Advise sought as well as a decent rebuildable early starter.
BTW, the bell housing isn't slotted, the sensors are new and the one is shielded, grounds are clean, why it's kicking back and killing starters I don't know.
I suspect fuel pressure regulator leak, gassing intake which may exacerbate the issue, not sure. Injectors do not seem to be leaking.
87 924S project, '83 944 engine,
my son's first car.
jvandyke
PostPosted: Wed May 29, 2019 11:53 pm    Post subject: Reply with quote
finallly sourced the "correct" early starter, the bigger bodied one and have not had a kick back issue since, note thet retailers won't differentiate starters and will supply the later, smaller bodied starter for all 944 and 924s and I am convinced these wreck havoc with our sensors. I finally found partsgeek listed the starters for early 944s and later as different numbers so I ordered the early one, it was fatter and is the magic bullet. IMHO.
pictures in this thread:
https://rennlist.com/forums/924-931-944-951-968-forum/986913-starter-interference-83-vs-87-a-2.html[/img]
my son's first car.
