Will 931 get any noticeable gains from ITB?
Shurick
PostPosted: Fri Feb 01, 2019 10:25 pm    Post subject: Will 931 get any noticeable gains from ITB? Reply with quote
I've seen massive gains in engine response and power on high-revving engines when upgraded ti ITB. But will it make any notable effect on a low compression and low revving 931 engine?
Any thoughts?
WBR, Shurick
'86 924S -- R.I.P.
https://www.instagram.com/ru_pacecar/
CÚdric
PostPosted: Fri Feb 01, 2019 10:31 pm    Post subject: Reply with quote
On/off throttle response will be better of course, but for power its more of getting the right length on the intake pipes for the power band you want,regardless of where the throttles sit.
┤80 924 Turbo
