Rear window heater matrix not working
Mskeet
PostPosted: Tue Jan 08, 2019 4:40 am    Post subject: Rear window heater matrix not working Reply with quote
Hi,
My rear heater screen was not working. I replaced the fuses, replaced the relay and tested, I had the little light on the switch working before. After all this I now have the light on the switch still working drivers door mirror warm but no power at the rear screen and the passenger side mirror cold - I am a RHD. Any thoughts greatfully recieved.
M
Lover of all things Porsche
1968 912
1988 924S
Ozzie
PostPosted: Wed Jan 09, 2019 7:14 am    Post subject: Reply with quote
Check the power (LHS) to the body with a meter.
biggest problem with these is people replace the struts with ones with plastic ends.
the RHS has to earth through itself and also has a sliding switch on it for interior light.
Its AUTO and its BLACK
Montego Black on black/red
PostPosted: Wed Jan 30, 2019 1:05 am    Post subject: Reattaching electrical connections Reply with quote
I recall somewhere recently there was a question on how to reattach the tabs if they came off...
Just stumbled across the answer:
https://www.frostfighter.com/defroster-repair-tab-bonding-kit-2000.htm
Long story short, seems you need a high silver-content adhesive...
