924 turbo 177hp (1981) oil pump rebuild
florent78
PostPosted: Thu Oct 11, 2018 8:11 am    Post subject: 924 turbo 177hp (1981) oil pump rebuild Reply with quote
Hi
my oil pump is in bad condition, I need to change the 2 pinions inside (too much play)
I cannot get a new one
price for custom rebuild is really expensive
it seems that the oil pump coming from the:
VW LT 2.5 tdi share the same internals
so I can buy it and rebuild it
I would appreciate some advices or tips
thanks for your help
PostPosted: Thu Oct 11, 2018 6:47 pm    Post subject: Reply with quote
Is it not worth sourcing another second hand/used pump that's not suffered the wear? They are the same in 2.0na and turbo. They rarely wear out unless exposed to poor oil + debris. I had 3 pumps to hand when rebuilding my engine. Only one of the 3 was slightly out of desired tolerance.
florent78
PostPosted: Thu Oct 11, 2018 9:38 pm    Post subject: Reply with quote
not easy to find
really the 2.0 NA and the turbo oil pump are the same ?
florent78
PostPosted: Thu Oct 11, 2018 11:28 pm    Post subject: Reply with quote
I checked on pics
they are different
from behind you can clearly see the plate and the number of screws is different
PostPosted: Thu Oct 11, 2018 11:50 pm    Post subject: Reply with quote
All na and turbo engine blocks and oil pumps ARE the same part. Only pistons are different.
If you don't have a 924 used parts supplier in France/EU then try https://wooliesworkshop.com/ in UK
florent78
PostPosted: Fri Oct 12, 2018 6:11 pm    Post subject: Reply with quote
thanks I asked them
but when I see the pics
the plate behind for the 924 turbo is 6 screws
the N/A is 3 screws
some there are some differences I think
PostPosted: Fri Oct 12, 2018 6:38 pm    Post subject: Reply with quote
Asked who?? What pics?
Porsche PET parts catalogue shows the same oil pump parts number for both NA and turbo application - 046 115 105 A ........go check
Ian89C4
PostPosted: Sat Oct 13, 2018 10:39 am    Post subject: Reply with quote
Agreed. They are the same part. I used an oil pump from a naturally asperated parts bin on my 931 rebuild. No issues. Would be interestwd to see the picture of the different pump you found.
The blocks are the same as well between the na and turbo. The only difference on the blocks is the angle of the breather pipe. Yes they are different part numbers, but I've them side by side and there are no cast differences.
Cheers
Ian Edgerly
Current:
1980ish 931 ("Alice")
