Can't remove sunroof
rod30
PostPosted: Sat Sep 29, 2018 1:28 am    Post subject: Can't remove sunroof Reply with quote
I would like to replace the seal on the sunroof of my 1987 924s. The roof tilts up and retracts just fine but the rear arms will not retract for removal. As I understand the process it should happen when the key is in the off position. Nothing happens when I move the rocker switch. Any ideas?
rod30
PostPosted: Sun Sep 30, 2018 3:24 am    Post subject: Can't remove sunroof Reply with quote
Well it seems as if I have no power when the ignition switch is turned once. I think this should provide power to retract the arms. Nothing else works in a acc mode. Anybody know what wire provides this power to the fuse panel? Bad ignition switch? I don't know where to look.
KDJones2000
PostPosted: Sun Sep 30, 2018 10:27 am    Post subject: Reply with quote
Key should be in the first position, not OFF.
Be careful you don't go too far and strip your gears.
1987 924S SPEC car
Team Toofah Racing
1988 944 Turbo S
Mskeet
PostPosted: Sun Sep 30, 2018 10:52 am    Post subject: Try Reply with quote
My sunroof is temperamental. Try switching the ignition on, press the sunroof raise button once, you should hear the arms retract?
Lover of all things Porsche
1968 912
1988 924S
