Which is faster?
vwfye
PostPosted: Wed Sep 12, 2018 3:15 pm    Post subject: Which is faster? Reply with quote
Dropping torque converter/trans or pulling the engine?
Russmw
PostPosted: Wed Sep 12, 2018 7:00 pm    Post subject: Reply with quote
Can I presume this is to do the clutch?
I've just finished this job and did it by removing the gearbox (5 speed), slide the torque tube back then remove the bell housing. In my opinion if you have an engine lift I suspect lifting the engine maybe easier\faster as access woudl be far better but then I did the job lying under the car and maybe with a 4 pillar lift would have a different opinion?
1982 924 2.0 Lux
(Alpine White)
vwfye
PostPosted: Thu Sep 13, 2018 12:56 am    Post subject: Reply with quote
Yep, my throwout bearing is very noisy right now.
vwfye
PostPosted: Thu Sep 13, 2018 12:58 am    Post subject: Reply with quote
My options are lying under the car under 4 jack stands or lifting out the engine.
PostPosted: Thu Sep 13, 2018 2:41 am    Post subject: Reply with quote
Unless you have another reason to pull the engine, just slide the torque tube/tranny back and remove the bell housing. Haynes has an OK write up.
snakoil
PostPosted: Thu Sep 13, 2018 7:18 am    Post subject: Reply with quote
getting the engine out means removing the Rad
Just having done the engine removal procedure, I believe removing the tranny might be easier
1979 924 NA
vwfye
PostPosted: Thu Sep 13, 2018 7:25 am    Post subject: Reply with quote
How much of a pain is pulling the shifter to slide it back?
Kenodog
PostPosted: Thu Sep 13, 2018 9:03 am    Post subject: Reply with quote
What series is your car ? 1 or 2 ...?
Me
1979 Euro 931, Olive
1981 931, Sabine
2014 Mazda CX-5 (Kid's limo)
2008 GS500
1996 Dodge Caravan (DJV)
vwfye
PostPosted: Thu Sep 13, 2018 9:06 am    Post subject: Reply with quote
Huh? 1980 2.0 n/a
Russmw
PostPosted: Thu Sep 13, 2018 7:42 pm    Post subject: Reply with quote
Mine was rattling\knocking when not in gear & at biting point which all sounded like it was coming from the back of the car. When I removed the inspection cover by the gearbox and grabbed the torque tube coupler I could rotate it by 100+ degrees.
After pulling the clutch it was clear the centre springs were really weak and the tabs in the middle off the clutch were banging against each outher - the release bearing was filthy but fine.
It was however the original clutch with a manufacturing date of July 1981 and the wear was quite low so backs up the 78k on the car.
I did the job with the car on axle stands\jacks and it was ok. More a write up here: https://www.porscheclubgb.com/forum/tm.aspx?m=1006375
Thanks
1982 924 2.0 Lux
(Alpine White)
vwfye
PostPosted: Fri Sep 14, 2018 1:03 am    Post subject: Reply with quote
Bookmarked your write up. Thanks for sharing!
