About rear spring plate.
MuteM
PostPosted: Fri Sep 07, 2018 7:55 am    Post subject: About rear spring plate. Reply with quote
Hi guys,
Question about rear spring plate.
On my 924 1979, I have two different spring plates.
So it should be?
PostPosted: Sat Sep 08, 2018 1:46 am    Post subject: Reply with quote
Both sides should look like the two on the left.
1979 924 NA race car
1982 924 Turbo almost a PoS
KDJones2000
PostPosted: Sat Sep 08, 2018 3:52 pm    Post subject: Reply with quote
The '76 cars had a rear suspension setup that didn't allow for ride height adjustment without reindexing the torsion bars.
Cars built after that had spring plates such that you could do some height adjustment with an eccentric bolt attached between the pivot point and the full spring plate.
It looks like you have one plate from a '76, and another plate from a later car.
Since yours is a '79, both should be 2-piece, like the one on the left as mentioned above.
1987 924S SPEC car
Team Toofah Racing
1988 944 Turbo S
MuteM
PostPosted: Sun Sep 09, 2018 4:02 am    Post subject: Reply with quote
Thanks a lot.
