Transmission making a clunking sound (video)
curtisr
PostPosted: Tue Sep 04, 2018 10:19 pm    Post subject: Transmission making a clunking sound (video) Reply with quote
The other day I noticed a clunking sound coming from the rear of the car. After determining the whereabouts of the kids and dog, I continued out of the driveway. It was then I noticed that the brake warning light on the consul was on. At first I thought it might be a dislodged e-brake shoe but taking the rotors off ruled that out. The e-brake also appears to be working properly.
The sound comes and goes with speed, coasting, and in neutral.
Here's a video of my turning the half-axle. The car is in neutral (manual transmission).
Any suggestions would be most appreciated. (And, yes, I know it sounds like 'Chain Gang'...)
https://drive.google.com/open?id=1t17YZnCXlmoRHxoeKpcmU33XB7iUedbb
World's worst welder.
kevingross
PostPosted: Wed Oct 10, 2018 11:31 pm    Post subject: Reply with quote
If the sound is coming from inside the transmission, you have either a broken ring and pinion or broken differential, best guess.
Kevin
Catellus Engineering, Inc.
http://www.catellusengineering.com/
catelluseng@gmail.com
curtisr
PostPosted: Thu Oct 11, 2018 12:52 am    Post subject: Reply with quote
Thank you, Kevin. Can you believe that it is so hard in this case to actually figure that out?!
curtisr
PostPosted: Thu Oct 11, 2018 12:53 am    Post subject: Reply with quote
I've decided that I am going to remove the transmission and redo the torque tube and clutch over the winter. This $hould $olve the mystery!
kevingross
PostPosted: Thu Oct 11, 2018 4:36 am    Post subject: Reply with quote
Well, if you don't fiddle with transmissions all the time, yeah, it could take a little figuring! Let me know if you need help with the transmission. Cheers,
Kevin
curtisr
PostPosted: Fri Oct 12, 2018 12:59 am    Post subject: Reply with quote
Promise. Thank you for the most generous offer.
