Dropped door - advice needed on repair
Mskeet
PostPosted: Fri Aug 31, 2018 8:51 pm    Post subject: Dropped door - advice needed on repair Reply with quote
Hi,
My divers door is dropped. The lower hinge on the body is moving from side to side slightly and needs welding. Does anyone know if the wiring loom is behind or below that area please?
Thanks in advance for any help.
Lover of all things Porsche
1968 912
1988 924S
snakoil
PostPosted: Fri Aug 31, 2018 9:30 pm    Post subject: Reply with quote
on 1979 the wiring is going along the door sill right under the plastic trim.
There are no wires behind the A pillar where the door hinges are mounted.
however be carefull as it is close to a hole on the side that is quite close to the auxiliary fuse box and a few wires for the rear lights and fuel pump.
1979 924 NA
Mskeet
PostPosted: Fri Aug 31, 2018 11:42 pm    Post subject: Many thanks Reply with quote
Anyone know if a 924s is different? Can't see why it would be.
1968 912
1988 924S
