Any advice on an oil leak?
Mskeet
PostPosted: Sun Aug 12, 2018 7:50 pm    Post subject: Any advice on an oil leak? Reply with quote
Hi,
I have a really small oil leak on my UK 1988 924S, I haven't been able to get it up on a ramp yet. Looking form the front of the car, the oil leak seems to be coming from high up on the left near the oil filter, it then runs along the roll bar and drips off from the centre of that. Before I start pulling things apart - would there be an obvious leak point in that location (oil filter aside!). Thanks in advance for any help.
Lover of all things Porsche
1968 912
1988 924S
16again2009
PostPosted: Mon Aug 13, 2018 4:24 am    Post subject: Reply with quote
The oil pressure sending unit and the oil cooler gasket were both leaking on mine. They are both in that area.
1988 porsche 924s
5 speed
Mskeet
PostPosted: Mon Aug 13, 2018 6:58 am    Post subject: Thanks Reply with quote
Just worried in case there is a danger it will be spaying back during driving over the belts.
1968 912
1988 924S
Moparboy72
PostPosted: Tue Aug 21, 2018 12:16 pm    Post subject: Reply with quote
Maybe the lower balance shaft seal, or balance shaft housing (o-ring) seal are always suspect in my book.
If the leak is very minor, I have used UV dye in the past to help track down the source of a small leak.
Good luck
Mskeet
PostPosted: Tue Aug 21, 2018 6:31 pm    Post subject: Thanks Reply with quote
I can get it up on a ramp this week and pin it down.
1968 912
1988 924S
Mskeet
PostPosted: Fri Aug 31, 2018 9:53 pm    Post subject: Thanks for replies Reply with quote
It was the oil cooler gasket, one on order.
1968 912
1988 924S
PostPosted: Sat Sep 01, 2018 8:42 am    Post subject: Reply with quote
The oil cooler gasket usually leaks antifreeze. Take a look at the oil cooler section of the shop manual here:
http://www.clarks-garage.com/
Mskeet
PostPosted: Sun Sep 02, 2018 6:14 pm    Post subject: Strange Reply with quote
It is only leaking oil. I have no milky coolant and no throthy oil, so must be oil side only.
1968 912
1988 924S
Mskeet
PostPosted: Thu Oct 04, 2018 9:29 am    Post subject: Problem solved Reply with quote
It was the oil cooler gasket and the oil pressure sender that were leaking. Both replaced and dry as a bone.
1968 912
1988 924S
