rod30
Joined: 05 Aug 2018 Posts: 20 Location: Carrolltom Mo
Posted: Tue Aug 07, 2018 5:02 am Post subject: Need help with connector |
I purchased a 924S that has been siting for years. I am trying to get it back on the road.There is a connector located at the firewall behind the valve cover. it goes to a sensor located near the speed and reference sensors. Nothing is plugged into it and I don't know what it is for. Any body know?
I don't know how to attach a photo. |
Joined: 02 Nov 2002 Posts: 9461 Location: Southeast Wisconsin
Posted: Tue Aug 07, 2018 12:10 pm Post subject: |
If it's round, might be for the O2 sensor. _________________ White 87 924S "Ghost"
rod30
Posted: Wed Aug 08, 2018 12:16 am Post subject: Need help with connector |
Thank you for the help. The connector is round. There is another connector next to it that does have something plugged in to it. That may the O2 sensor. When I follow the wire it takes me to the area where the speed and reference sensors are. This sensor looks like a speed sensor and is in a hole next to the speed and reference sensors. You know how the adjusting plate has three holes that could have a sensor in it? This is in the third hole. This is a white 1987 like yours. |
16again2009
Posted: Wed Aug 08, 2018 6:59 am Post subject: |
That is the TDC sensor used by the factory when the car is new. I have one on my 1988 924s. It doesn't plug into anything. It was used by the factory once. If you ever have to change your speed/ ref sensors, you can take it off and throw it away. _________________ 1988 porsche 924s
5 speed |
rod30
Posted: Wed Aug 08, 2018 7:06 am Post subject: Need help with connector |
Thank you. That is the best answer I could have gotten. I will remove it. |
