Temp gauge not working
Johnparmenter82
PostPosted: Mon Aug 06, 2018 8:14 am    Post subject: Temp gauge not working Reply with quote
I did a full engine rebuild....finally finish but the temp gauge is not working. Is it most likely the sensor behind the head?
Johnparmenter82
Ian89C4
PostPosted: Mon Aug 06, 2018 11:36 am    Post subject: Reply with quote
If it was working prior to the engine rebuild I would say yes. Did you clean the temp sender? The plastic can crack on the outside and I have found different readings from the ones with the cracked plastic.
Cheers
Ian Edgerly
Current:
1980ish 931 ("Alice")
PostPosted: Mon Aug 06, 2018 7:50 pm    Post subject: Reply with quote
Plus check your wires thoroughly.......just been through all of that!
PostPosted: Mon Aug 06, 2018 7:51 pm    Post subject: Reply with quote
Johnparmenter82
PostPosted: Sat Sep 01, 2018 9:40 am    Post subject: Reply with quote
Bad connection...problem solved!
Johnparmenter82
