Torsion Bar Adjustment
PostPosted: Tue Jul 24, 2018 11:15 pm    Post subject: Torsion Bar Adjustment Reply with quote
With my GAZ rear shocks the spring is just intended to be a booster and the torsion bar still controls the ride height. I have put holes in the body and welded nuts to the t-bars so they can be pulled out without removing the T-bar carrier.
Is there a format for adjustment on the car o rdo I just measure where I am, figure the rotation I would need if using a torsion bar of the equivalent total spring rate, disconnect the shock and adjust it.
Mike
'77 924
cricketdesigns.com
PostPosted: Wed Jul 25, 2018 1:24 am    Post subject: Reply with quote
I'm not sure I understand your question, what are you trying to adjust exactly? Ride height, corner weight, damper settings or coilover perch height?
'79 924 #77 ITB racecar
jazz guy
PostPosted: Wed Jul 25, 2018 3:41 am    Post subject: Reply with quote
You might try knocking around around the Rennlist site for info on rear coil/torsion bar setups. I have seen a number of threads regarding your setup and full torsion deletes in the Watercooled 924/931/944/968 Forum through the years. Also the racing & turbo 944 forums have discussed this. I apologize that I don't have a specific thread to link but the Rennlist search is reasonably easy to use.
'81 931
'82 931
KDJones2000
PostPosted: Wed Jul 25, 2018 4:08 pm    Post subject: Reply with quote
Go here, Grasshopper....
http://944-spec.org/944SPEC/technical-articles/42-torsion-bar-re-indexing
1987 924S SPEC car
Team Toofah Racing
1988 944 Turbo S
Post new topic   Reply to topic    924Board.org Forum Index -> 924 Racing Today All times are GMT + 11 Hours
