Excessive vibration at high RPM
Juhana
PostPosted: Wed Jul 18, 2018 5:55 am    Post subject: Excessive vibration at high RPM Reply with quote
Hi need your help guys,
I was on a nice evening drive when I unexpectedly hit a bump in the road pretty hard. My car is low and running coilovers so parts of the underside probably hit the road when i ran into the bump. After the bump I started noticing excessive vibration at high rpm. I drove home slowly and lifted the car. The underside seems fine and nothing seems to have come loose. What could be causing the vibration? Exhaust is fine and has not come loose. Could this be a result of failed engine mounts?
My car is a 1985 924 2.0
Thanks in advance
PostPosted: Wed Jul 18, 2018 10:00 am    Post subject: Reply with quote
bent wheel.
1981 924 Turbo sold
1982 924 Turbo sold
Ian89C4
PostPosted: Wed Jul 18, 2018 8:26 pm    Post subject: Reply with quote
Bent wheel or a blown tie rod end I would say. Doubt that would destroy a motor mount.
With a bad motor mount you will feel it more at idle, and you will hear the exhaust banging on the torque tube tunnel. Just had to replace mine on the 931 and those were the symptoms.
Good luck.
Ian Edgerly
North Carolina
Current:
1980 924 Euro ("Wahala")
Juhana
PostPosted: Thu Jul 19, 2018 6:11 am    Post subject: Reply with quote
Found the problem. The impact did indeed crack one of the motor mounts. The mount must have been on itīs way out already for that to happen. Easy enough fix thank god.
Ian89C4
PostPosted: Sat Jul 21, 2018 10:22 pm    Post subject: Reply with quote
Well I'll be darned. Good spot!
Glad it's an easy fix.
Ian Edgerly
North Carolina
Current:
