*URGENT* Info Needed Please
Kenodog
PostPosted: Fri Jun 01, 2018 12:21 am    Post subject: *URGENT* Info Needed Please Reply with quote
I got a call from the shop building Olive's new motor and the mechanic asked me for the diameter of the rod and block bearing surfaces. I have the journal diameters but he needs the OD sizes where the bearings fit onto. The factory manual does not state this info and I cannot actually think why he would need it except to be able to calculate bearing play...
Anyone ?
Lee
1979 Euro 931, Olive
1981 931, Sabine
2014 Mazda CX-5 (Kid's limo)
2008 GS500
1996 Dodge Caravan (DJV)
PostPosted: Fri Jun 01, 2018 12:30 am    Post subject: Reply with quote
Somebody with an open block may be able to help if they had the caps and the right measurement equipment.
I can get you the rod big end diameters(where the bearings go) but I cant help you with the block dimensions.
red 924 and not red 924
Kenodog
PostPosted: Fri Jun 01, 2018 1:41 am    Post subject: Reply with quote
Thanks brother that would be helpful. The only reason I can think he would need this is because of the clearance tolerances for the bearing caps. Never been asked this before.
Leg
1981 931, Sabine
2008 GS500
Brockoli
PostPosted: Fri Jun 01, 2018 1:47 am    Post subject: Reply with quote
I have my '79 block that I could measure. The block was align honed when I rebuilt it. Not sure if that makes a difference. I only have calipers to measure. Would that be accurate enough?
'80 924 M471,Wideband O2, Full coilover susp,23/19 sways,Bilstiens,KLA Strut Brace,Roll Bar,Test Pipe,BBS RS, Willwood BBK
25% of a '87 944 Chumpcar http://straightpipe.ca/forums/showthread.php?t=2454
'79 924 Sebring Edition(Sitting)
Kenodog
PostPosted: Fri Jun 01, 2018 2:21 am    Post subject: Reply with quote
Thanks guys but I found the info. Helps to have your glasses on when reading tech manuals lol !
Leigh
1981 931, Sabine
2008 GS500
