Option Code E17?
Moparboy72
PostPosted: Thu May 24, 2018 6:26 am    Post subject: Option Code E17? Reply with quote
Looking through the many links and sources I was curious if anyone has come across a listing for code E17?
1982 931; the only options are C02 (US Emissions) and E17 (?)
Thanks,
Andrew
PostPosted: Sat May 26, 2018 12:36 pm    Post subject: Reply with quote
Do you have a retractable tow hook?
Moparboy72
PostPosted: Sun May 27, 2018 4:06 am    Post subject: Reply with quote
I don't believe so; the front has the standard welded on loop, the rear loop looks to have been ripped off from a strong tug.
Do you have a photo/link as to what the retractable tow hook would look like?
Thanks for the response,
Andrew
Moparboy72
PostPosted: Fri Jul 27, 2018 3:25 am    Post subject: Reply with quote
I am curious if this is a code for a package of equipment?
The car is fitted with 16" wheels and a rear sway bar both of which I thought were optional equipment but maybe by '82 the US spec cars received what ever parts were sitting at the factory?
Other items fitted to the car which I believe are all US standard equipment:
Power windows
Rear wiper
Manual Sunroof
Power Mirrors
A/C
Thanks for any direction,
-Andrew
Moparboy72
PostPosted: Tue Aug 21, 2018 10:57 am    Post subject: Reply with quote
In case this helps:
https://i.imgur.com/q71GElF.jpg?3
Moparboy72
PostPosted: Thu Apr 02, 2020 5:08 am    Post subject: Reply with quote
Does anyone else have E17 listed on their build tag?
Thanks!
