fron rear axles weights?
musicalannette
PostPosted: Thu May 10, 2018 3:28 am    Post subject: fron rear axles weights? Reply with quote
Hi.
One thing I didn't do I meant to do before the car was written off was take it to a weigh bridge.
Does anyone have the weight of the car front in kg's and rear in kg's.
Jus by driving each end on to a weigh bridge?
I thought this might be slightly different for different models and gearboxes.
Thanks.
Thanks for the help. 924 gone.....
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger
PostPosted: Thu May 10, 2018 4:29 am    Post subject: Reply with quote
We scale ours regularly; weights are in pounds:
https://www.facebook.com/photo.php?fbid=10203178754744543&set=pb.1678056378.-2207520000.1525886882.&type=3&theater
PostPosted: Thu May 10, 2018 11:03 pm    Post subject: Reply with quote
Additional info... note that the scale numbers posted are without driver, gutted car with cage, approx 3/8 tank of fuel. Things even out side-to-side better with the driver installed.
Also note that we've typically found the racecar to be 49/51% front/rear bias, due to the lack of interior... whereas when I scaled my 82 931 ages ago I found it more like 51/49% front/rear - though at the higher weight with interior etc.
HTH...
