Windshield washer parts
emhewitt
PostPosted: Wed Apr 11, 2018 6:44 am    Post subject: Windshield washer parts Reply with quote
Need to find windshield washer pump, fluid tank, tubing and any other parts to get system working. My car is an 81 931. Thanks
Michael Hewitt
PostPosted: Wed Apr 11, 2018 9:58 pm    Post subject: Reply with quote
Any tubing, such as from the local autoparts store, should work.
Tank and pump, also valve and nozzles... I know I've seen 'em new at I think 944online.com...
Eric P
PostPosted: Thu Apr 12, 2018 1:15 am    Post subject: Reply with quote
I bought all the stuff I needed on eBay.
The pump was URO part replacement but seems to work well for about $12.
PN: 823955651 (this is the vw part number, but it clips right onto your washer tank)
The check valves I used were made for a saab.
90* check valve, PN: 8573669
T check valve, PN: 5142765
Reservoir cap:
VW PN: 477955455
The hose I bought was 3/16" clear polyurethane tubing. It doesn't get hard like vinyl tubing. I like the fact that you can see the fluid in the line. You can get tons of different colors in varying transparency though. blue, pink, green, yellow, you name it. You could probably get away with 3/16" rubber fuel line from the auto parts store if you don't like being able to see into the lines.
The only things I didn't replace were the nozzles and tank as they were in good shape. I just had to poke the nozzles out with a pin. I'm sure there's a VW equivalent if you need them though. The tank will probably be the hard part. I would start by posting here in the wanted section, looking on eBay, and maybe looking for a local salvage yard if you come up empty handed.
1980 924 NA, US model
1987 924S, US model
