Interchangeable body parts from 944?
924buzz
PostPosted: Mon Apr 09, 2018 4:03 am    Post subject: Interchangeable body parts from 944? Reply with quote
So I acquired a 924s racecar with front end damage. Both horns bent badly in front of the engine cross member. The front end of the car had already been removed when I got this car.
I have been told that I can graft a 944 front section onto this chassis and that body panels except fenders and valance would be the same.
Is this true? Can I use the hood, head light panel and covers and bumper?
There does not appear to be any damage behind the engine cross member. Door shut lines are good and doors open and close normal.
Thanks for any replies.
Charlie
2010 NASA GTS-1 National Champion
2010 NASA 944 Spec 2nd bridesmaid
2010 NASA So-Cal 944Spec Regional Champion
2009 NASA 944 Spec National Champion
2009 NASA GTS-1 National P4
snakoil
PostPosted: Mon Apr 09, 2018 9:52 pm    Post subject: Reply with quote
the front bumper from a 944 will not fit the 924 fenders
Simply use the 944 front fenders instead of the 924 and you will be good to go
1979 924 NA
