924 carburetor conversion
Juhana
PostPosted: Sat Mar 31, 2018 3:30 am    Post subject: 924 carburetor conversion Reply with quote
Hey guys,
New member here. I Recently bought a 1985 924 and I intend to restore it to as original as possible. My car has had a carburetor conversion done and my question is how would I go about restoring it back to the original injection system? Is this doable?
Thanks in advance
924-76
PostPosted: Sat Mar 31, 2018 3:42 am    Post subject: Reply with quote
Hi and welcome aboard!
Yes it can be done, you just have to find all the parts.
Be aware this will not be cheap. Also, it is recommended to have the fuel distributor and warm up regulator professionally rebuild as they are the two main cause of problem related to CIS (apart from vacuum leak) and for reliability.
1976 924 N/A ROW SOLD
1980 931S
1981 931 Part car RIP
Juhana
PostPosted: Sat Mar 31, 2018 3:59 pm    Post subject: Reply with quote
Thanks. Will definitely look into getting professional help for the fuel distributor and warm up regulator. As far as parts go, where would you recommend sourcing them? I've used Rosepassion previously and they're great but they don't have everything.
CÚdric
PostPosted: Sat Mar 31, 2018 5:39 pm    Post subject: Reply with quote
I would try sourcing all parts from someone scrapping a 924 nearby, then they can be had very cheaply. And then rebuild wur and fuel distributor.
If you can't find them maybe try the Swedish board 944sverige.com
┤80 924 Turbo
PostPosted: Sat Mar 31, 2018 7:28 pm    Post subject: Reply with quote
All OEM parts on Rosepassion can be had from an Official Porsche Centre. If they are not listed on Rosepassion, then they are not available at Porsche.
