Door drain holes
procyon
PostPosted: Tue Feb 27, 2018 11:44 am    Post subject: Door drain holes Reply with quote
Are there any drain holes in the interior of the two doors? I have the two door cards off and I am trying to make sure that any water that might get in there has a way out; I cant seem to find drains in either side.
Are there no drains?
I thought cars usually had drains or something to let any water out.
1981 924 N/A (Now the parts car)
1980 924 N/A ( 5 bolt discs and better paint) MS II V3.57
2003 Subaru Baja
2005 Toyota Camry
porsche_reg
PostPosted: Thu Jun 21, 2018 12:07 pm    Post subject: Reply with quote
I've had my door cards off many times, I don't think there's much in the way of a drain hole. There's the large vents at the end of the door, in middle, but I don't think there's anything at the bottom.
Certainly open to learning more if others have more info.
Prev: '81 BMW 320i
'05 997.1 C2
Current: '79 924 n/a (family owned since new)
'12 Subaru Outback
snakoil
PostPosted: Thu Jun 21, 2018 9:20 pm    Post subject: Reply with quote
with the amount of water I once had in my doors i'm pretty sure there is none.
I ended up drilling a small hole to let the water out
1979 924 NA
kingzetts
PostPosted: Thu Jun 21, 2018 11:33 pm    Post subject: Reply with quote
There are drain holes in the base of the doors, built in to the inward-facing flange where the inner and outer door skins meet. They’re like long slots where the flanges don’t quite meet. Look right at the edge of the base of the door from the cabin side, below the seal.
They can block with debris, or if someone has injected wax in the door cavity. Use a piece of stiff wire to poke out any blockage.
John,
1980 924 turbo "timewarp" being restored
v8carreragts
PostPosted: Tue Jul 10, 2018 4:08 pm    Post subject: Reply with quote
Also the factory used heavy plastic sheet cut and attached to the doors before the cards went on. These keep the water off that drips from the glass area.
P/N's
up to 82
477.867.177 D left
477.867.178 D right
83 and up
477.867.179 left
477.867.180 right
84 944--924 Carrera GTS clone w/520HP Chevy 302 V8--RUNNING!
2015 AUDI Q7
2013 Chevy Cruze
