Joined: 08 Jan 2010 Posts: 1653 Location: Somerset, UK
Posted: Wed Feb 21, 2018 8:50 pm Post subject: KKK K26 compressor wheel technical drawings needed please |
Anyone have the KKK technical drawings with dimensions for the following compressor wheels?
2470 - have wheel - no KKK drawing
2660 - need wheel - no KKK drawing
2664 - wheel on its way - no KKK drawing
2670 - have wheel - have KKK drawing
They clearly differ in dimensions as the relative compressor housings all have differing part numbers. Would be great to see drawings and physical wheels to see the differences and what parts are potentially interchangeable if at all.
Thanks in advance.......  _________________ 1980 931 - forged pistons, Piper cam, CGT turbo, 951 ducted FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife LSD
Joined: 23 Jul 2007 Posts: 1009 Location: The Netherlands
Posted: Sat Feb 24, 2018 4:50 pm Post subject: |
What project are you working on ? _________________ 937 trackday car
937 DITC
Posted: Sat Feb 24, 2018 7:16 pm Post subject: |
Dutch924-racer wrote: | What project are you working on ? |
Just want to compare wheels out of curiosity. Dimensions. Shapes. See what differences exist. Check if my existing wheel is as the re builder said it was, a 2660 or not. Maybe instal the 2670 wheel I have, understand the machining required of the housing. Looking for facts not opinion and hearsay. Will pass on info to Cedric who is doing some efficiency modelling. _________________ 1980 931 - forged pistons, Piper cam, CGT turbo, 951 ducted FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife LSD
gegge
Posted: Sat Feb 24, 2018 8:36 pm Post subject: |
I got a 2660-4.1 turbo on the shelf and can take some measurements, if you want me to but not interested parting/selling the wheel only. _________________ Carl Fredrik Torkildsen
924s -86 Black on black with low ET "Phonies" |
Posted: Sun Feb 25, 2018 12:48 am Post subject: |
gegge wrote: | I got a 2660-4.1 turbo on the shelf and can take some measurements, if you want me to but not interested parting/selling the wheel only. |
Measurements and photos would be really helpful please. _________________ 1980 931 - forged pistons, Piper cam, CGT turbo, 951 ducted FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife LSD
gegge
Posted: Sun Feb 25, 2018 2:26 am Post subject: |
2660 compressor wheel
Height of tip: 3,9mm
Height from backplate: ~22mm
Radius of inlet: ~20mm
Thickness of blade: 1,5mm
Inducer: 39,8mm
Exducer: 66,0mm
Note: the backplate is counterbored and the flatback compressorwheel exducer is therefore in level. The 5326-123-2007 and 5326-123-2017 wheels are 5,2mm according to unknown (but trusted) source.
5326-123-2006, 5326-123-2016 & 5326-123-2035 are 7,2mm
5326-123-2010, 5326-123-2019 & 5326-123-2038 are 6,3mm
5326-123-2039 from 951 is unknown but also flatback. Worth to investigate...
5326-123-2201 from 951S is a superback but measure 4,9mm
EDIT: http://www.turbomaster.info/eng/applications/compressor_3k.php _________________ Carl Fredrik Torkildsen
Posted: Sun Feb 25, 2018 7:23 am Post subject: |
Similar on eBay too _________________ 1980 931 - forged pistons, Piper cam, CGT turbo, 951 ducted FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife LSD
