Raize
Posted: Sun Dec 03, 2017 9:56 am Post subject: Welded differential |
Has anyone welded the differential on a 924? Is it even possible with our transaxle gearboxes? What's the handling like? |
Posted: Sun Dec 03, 2017 8:56 pm Post subject: |
It’s been done on drift 944’s. Handling will be very sideways _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
Raceboy
Posted: Mon Dec 04, 2017 1:57 am Post subject: |
I used welded diff on my Gulf, it was better than Torsen I used before. At least on the tracks I used (faster tracks).
On very narrow ones could be hit or miss: you get better traction out of the corner but may get understeer or little bit of loose rear end.
Understeer will be when you have low power and soft supension, so it is not recommended in those circumstances _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
Joined: 28 Feb 2008 Posts: 1354 Location: Washington DC area
Posted: Mon Dec 04, 2017 2:35 am Post subject: |
I've welded the dif on each (Audi and snailshell boxes) of my 924 race cars as well all of my other race cars over the years. It takes some getting used to with low speed understeer but the high speed oversteer is best for racing.
I've also raced with LSDs and Torsen difs but like the welded the best. No additional heat generated vs the clutch types and no jerkiness like the Torsen. _________________ 1979 924 NA race car
1982 924 Turbo almost a PoS
daniel
Joined: 18 Jun 2009 Posts: 670 Location: Sydney, Australia
Posted: Mon Dec 04, 2017 8:23 am Post subject: |
I have my diff welded on my 924 race car with Getrag gearbox. Big improvement in the dry - slightly backwards in the wet.
Don't try to push onto the trailer! _________________ Over the top of skyline, total brake failure.... hit the wall at over 200 kp/h at the dipper, so anyone who has to brake for the esses is a pussy.
1989 944 Cabriolet |
kevingross
Joined: 15 Apr 2015 Posts: 34 Location: Stow, MA, USA
Posted: Thu Dec 14, 2017 1:49 pm Post subject: |
Not a great idea for street use - the differential was after all invented for a reason. For a track, it will depend, generally useful for large ovals with wide, open corners.
The big negative is that if you have a failure on one side of the diff, such as a broken half-shaft, the car will snap turn you into whatever is next to you faster than you can react. Dangerous. _________________ Kevin
Catellus Engineering, Inc.
http://www.catellusengineering.com/
catelluseng@gmail.com |
daniel
Posted: Fri Dec 15, 2017 9:13 am Post subject: |
Equally dangerous both ways. I had a CV joint go on me mid corner whilst still running the open diff and the sudden power cut sent me sideways. I only just managed to avoid riding my self and car out on a concrete wall _________________ Over the top of skyline, total brake failure.... hit the wall at over 200 kp/h at the dipper, so anyone who has to brake for the esses is a pussy.
