Problem on track
chris79
PostPosted: Thu Nov 23, 2017 5:52 pm    Post subject: Problem on track Reply with quote
During a trackday I had this problem, minimum unscrewed itself and go 2000 rpm, can this reduce engine power ?
In addition to this sometimes the plate seems don't move and I have to wait some minutes before I can accelerate.
PostPosted: Thu Nov 23, 2017 6:15 pm    Post subject: Re: Problem on track Reply with quote
that must be hard on your lap times
red 924 and not red 924
chris79
PostPosted: Thu Nov 23, 2017 8:53 pm    Post subject: Reply with quote
Yes after only 10 minutes this problem, I'm not lucky, now I regulated the plate, but may be controll pressure too high.
But I want to know if wrong minimum rpm can reduce max speed, only 180 km/h
PostPosted: Thu Nov 23, 2017 10:10 pm    Post subject: Reply with quote
what RPM do you have at 180kph?
chris79
PostPosted: Fri Nov 24, 2017 4:03 am    Post subject: Reply with quote
I don't know, but from acceleration start at about 60 km/h to end of straight after 30 seconds I think I have to reach 200 km/h.
PostPosted: Fri Nov 24, 2017 7:57 pm    Post subject: Reply with quote
with a good engine, good clutch and correct size tires, yes.
chris79
PostPosted: Sat Nov 25, 2017 7:26 am    Post subject: Reply with quote
The new suspension setup is very good, Bilstein b6, lowered red springs, swaybars, the roll is very low and feeling good.
Rear spacers reduce understeering.
It would take only light more power on engine.
