Hi from Norway...
Emil13
PostPosted: Wed Nov 15, 2017 10:27 pm    Post subject: Hi from Norway... Reply with quote
My name is Emil
I live in Norway(24years)
but is from Poland
This is my Porsche 9x4 No. 4
2x944 NA
2x924
I work as a technician / and electrician
on DAF trucks or VDL buses.
My English is not so good so to write using google translate
but because of work technical english is ok...
nice forum and lots of great information ...
(can also write Norwegian and Polish if there are members with this language ....)
Emil
Moss
924.pl
DAF norge AS
autonor.no
84-924
82-944
84-944
78-924
PostPosted: Wed Nov 15, 2017 11:05 pm    Post subject: Reply with quote
welcome, lets see some pictures
red 924 and not red 924
Emil13
PostPosted: Thu Nov 16, 2017 1:24 am    Post subject: Reply with quote
12 years ago porsche 924 no 1
(944 rear or front axel)
Moss
924.pl
DAF norge AS
autonor.no
84-924
82-944
84-944
78-924
Emil13
PostPosted: Thu Nov 16, 2017 1:29 am    Post subject: Reply with quote
10years ago
944 NA
Moss
924.pl
DAF norge AS
autonor.no
84-924
82-944
84-944
78-924
Emil13
PostPosted: Thu Nov 16, 2017 1:33 am    Post subject: Reply with quote
7 yers ago...
944 NA
Moss
924.pl
DAF norge AS
autonor.no
84-924
82-944
84-944
78-924
PostPosted: Thu Nov 16, 2017 1:39 am    Post subject: Reply with quote
and the 78?
Emil13
PostPosted: Thu Nov 16, 2017 1:46 am    Post subject: Reply with quote
Today..
1979 924
Moss
924.pl
DAF norge AS
autonor.no
84-924
82-944
84-944
78-924
Emil13
PostPosted: Thu Nov 16, 2017 2:03 am    Post subject: Reply with quote
09.06.2017
Today
Moss
924.pl
DAF norge AS
autonor.no
84-924
82-944
84-944
78-924
PostPosted: Thu Nov 16, 2017 6:57 pm    Post subject: Reply with quote
Nice collection.......and all shiny!
Emil13
PostPosted: Thu Nov 16, 2017 7:58 pm    Post subject: Reply with quote
Thanks,
but have hot start problems with 78-924
new fuel accumulator, pump, cables +++
CO its ok,
Coold starts well, but not after 8-10<min. after stop.
tried with other warm up no better
and reserve fuel distrybutor no better ...
Moss
924.pl
DAF norge AS
autonor.no
84-924
82-944
84-944
78-924
PostPosted: Thu Nov 16, 2017 10:22 pm    Post subject: Reply with quote
When starting with a hot engine, press accelerator pedal to the floor during cranking. When it fires up immediately release accelerator pedal.
Also, a fuel pump relay that keeps the fuel pump running for more seconds(with the engine not started) is helpful.
Emil13
PostPosted: Fri Nov 17, 2017 12:06 am    Post subject: Reply with quote
I press accelerator so it helps,
but seems like it starts at 2 so it comes 3-4 cyl after 2/3 seconds.
built pump relay for new type reley 433906059 or coupled volvo pump relay
to newer type 924 relay so it pumps for 3 sec when ignition set on.
Not helps... 😡
( volvo reley 898797000 fuel pump controller
+ from battery 15
+ to 924 relley + inn 87
-to grond 31
- to - in coil 31B
its working ok...)
I Have one to volvo relay and
should build it to power to warmup tts +++
so when ignition is on them for no power only with engine is running.
on my 924 tts, warmup,AAV,++starts with ignition and on the cold engine they get hot and faillure a bit with start if i veiting exempel 4-6 minut with ignition on..
Moss
924.pl
DAF norge AS
autonor.no
84-924
82-944
84-944
78-924
Emil13
PostPosted: Fri Nov 17, 2017 1:29 am    Post subject: Reply with quote
Fixit today...
35mm spacere rear axle..
Moss
924.pl
DAF norge AS
autonor.no
84-924
82-944
84-944
78-924
snakoil
PostPosted: Sat Nov 18, 2017 12:21 am    Post subject: Reply with quote
Dzien Dobry, Mi to mi
(please don't start talking polish as these are the only words I know)
1979 924 NA
Emil13
PostPosted: Sat Nov 18, 2017 2:03 am    Post subject: Reply with quote
I fix the warm up regulator today so no more
hot start problems...
(more cold pressure or more hot pressure)
Moss
924.pl
DAF norge AS
autonor.no
84-924
82-944
84-944
78-924
