Won't start, coming off engine rebuild
Johnparmenter82
PostPosted: Sat Oct 28, 2017 10:32 am    Post subject: Won't start, coming off engine rebuild Reply with quote
Getting power but won't turnover, no clicking, no nothing. I'm getting power and lights and tried my battery pack but still nothing.
Johnparmenter82
Ian89C4
PostPosted: Sun Oct 29, 2017 12:35 am    Post subject: Reply with quote
Did you give the solenoid on starter a tap with a hammer? Sometimes sitting that long, if not replaced, they can just get a little stuck.
Does the engine turn by hand?
Once she turns on her own with the starter, if still no start, then start the air, fuel, spark trouble shooting that we all love.
Good luck.
Cheers
Ian Edgerly
Current:
1980ish 931 ("Alice")
PostPosted: Sun Oct 29, 2017 4:47 am    Post subject: Reply with quote
Make sure you have installed the engine ground wire from the coil area to the block properly.
PostPosted: Sun Oct 29, 2017 6:07 am    Post subject: Reply with quote
Are the 16 and 50 wires connecting to the starter solenoid reversed? If so get nothing.
Mike
'77 924
cricketdesigns.com
sciroccosteve
PostPosted: Sun Oct 29, 2017 7:36 am    Post subject: Reply with quote
I helped with the rebuild, some things still not attached, I didnít think that ground from coil bracket to block would be an issue?
2000 V6 Passat
"Let the fools have their tar tar sauce."
C. Montgomery Burns
PostPosted: Sun Oct 29, 2017 9:25 am    Post subject: Reply with quote
Absolutely will cause the issue. On NA cars I've seen the clutch cable melt and snap when trying to start the motor with this ground disconnected.
