Youtube video of record 924 Bonneville run
Qik Nip
PostPosted: Sat Oct 07, 2017 4:20 am    Post subject: Youtube video of record 924 Bonneville run Reply with quote
Not sure if this link pasted below will work from the site, but for anyone interested, here is the video of the run at Bonneville we made setting the G/PRO record in the 924 in August of this year.
If you look closely at the iPhone taped to the dash (running a GPS speed app) we hit 150 at the three mile mark. You'll also see the shift light burning brightly in fifth gear at that point - indicating that the engine was running something above 8,300 for some eight seconds. That RPM should (theoretically) have resulted in a ~165 MPH speed, but the rear wheels were slipping due to aero lift at that speed. Hopefully the spoiler we just installed will end that problem!
Rick
https://www.youtube.com/watch?v=hbX7kL-c7hc
'79 NA 924 Land Speed Car
Bonneville G/CPRO record holder @ 149.825MPH
'96 LT4 C4 daily driver
PostPosted: Sat Oct 07, 2017 6:41 am    Post subject: Reply with quote
Very interesting and different from stuff I'm used to.
red 924 and not red 924
PostPosted: Sat Oct 07, 2017 7:24 pm    Post subject: Reply with quote
Awesome video, just wish the sound was better but maybe it's my phone..
PostPosted: Sat Oct 07, 2017 11:32 pm    Post subject: Reply with quote
Very cool! Looking forward to your next update!!!!!!!
Cédric
PostPosted: Sun Oct 08, 2017 1:33 am    Post subject: Reply with quote
Cool clip, especially for us where running on salt flats feels like a different world running with the spoiler will both reduce drag and lift, should yield good results, do you run the stock undertray at the front?
´79 924
´80 924 Turbo
gegge
PostPosted: Sun Oct 08, 2017 3:53 am    Post subject: Reply with quote
Tell us more about the engine. Are you revving the stock 2l to 8300? Sounds like you need different gearing if you can do 8 sec in top gear on a salt lake. 165mph is a lot by the way!
Carl Fredrik Torkildsen
Ian89C4
PostPosted: Sun Oct 08, 2017 9:30 am    Post subject: Reply with quote
Very Nice! Congrats again
Ian Edgerly
Current:
1980ish 931 ("Alice")
Qik Nip
PostPosted: Mon Oct 09, 2017 2:53 am    Post subject: Reply with quote
Yes I do. Regrettably the class in which I run limits aerodynamic improvements to lowering and removal of mirrors. Can't even tape up body seams.
Rick
Qik Nip
PostPosted: Mon Oct 09, 2017 3:20 am    Post subject: Engine answers Reply with quote
Carl:
It's a naturally aspirated 2 liter with pretty extensive modifications (by the engine builder Michael Mount). In reality all that remained stock 924 was the block and crankshaft. It has a 924 turbo head which permitted installation of larger custom made valves and room for opening up both the intake and exhaust ports, custom made (J&E) pistons (13.6:1), Cunninghan rods, a dry sump oiling system, twin 50mm DCOE Webers via a custom fabricated intake, a custom fabricated stainless header, a custom cam with .525" lift, inner Isky and outer 944 valve springs, and an electronic ignition system. When dynoed it peaked at 8,300 RPM's - although it will pretty safely spin at 8,500.
As for more gearing ... and spinning the tires, we think the issue is aero lift. I'm told that the 924 might be creating ~600 pounds of lift at the rear at 150 MPH. Given the car's 2,400 pound weight, that would mean only 600 pounds on the rears at speed ... ergo spinning tires. Our hope is that the rear spoiler will kill that lift and that the engine will have enough torque to accelerate the car closer to 160.
Rick
gegge
PostPosted: Mon Oct 09, 2017 6:15 am    Post subject: Reply with quote
Interestering indeed.
The 933 wasn´t able to deliver more than 180 bhp @ 7500. How much does your head flow? 180-190cfm? Making more than 200bhp is difficult given these constrains.
According to the Porsche 924 SAE papers, rear axle lift at 210kph was 80N without a spoiler, due to a "somewhat elevated rear profile" The integrated front spoiler reduce lift to 30N at the same speed. Adding a rear spoiler would reduce rear lift at the expence of increased front lift. But the benefit of an improved Cd from 924 NA 0.36 to 924 turbo 0.34 with the tiny rear spoiler is a major improvement
Cédric
PostPosted: Mon Oct 09, 2017 6:23 am    Post subject: Reply with quote
Didn't the evolved 925 'gt3' 933s have 200-230 hp?
´79 924
´80 924 Turbo
Qik Nip
PostPosted: Tue Oct 10, 2017 2:35 am    Post subject: Reply with quote
Carl:
Are you saying that SAE paper reported that the rear lift with no spoiler is just 60 Neutons (17.6 pounds) at 210 KPH (137 MPH)? That seems somehow off by perhaps an order of magnitude. Or did I error in my Newton to pounds conversion?
Rick
PostPosted: Tue Oct 10, 2017 5:54 am    Post subject: Reply with quote
Perhaps, but not with the 2.0L. Most of these in the GT class, as far as I am aware, were converted to 2.5L. If they were based on the 2.0L block, they were almost certainly bored and stroked. Will have to go back to Roy Smith's book and the chapter on the 933 program to confirm...
PostPosted: Tue Oct 10, 2017 5:55 am    Post subject: Re: Engine answers Reply with quote
You didn't mention lifters...I presume you are not using the OEM lifters? They are known to crack at about 7500 RPM.
Qik Nip
PostPosted: Tue Oct 10, 2017 6:46 am    Post subject: Re: Engine answers Reply with quote
Good catch...No they're 38.5 mm lifters from a European maker (Ventiltryckare?). Got them from a Swedish outfit named ACM.SE. So far no failures.
Rick
