Porsche 924, Race weekend in car footage
Robert Hooper
PostPosted: Fri Oct 06, 2017 6:21 am    Post subject: Porsche 924, Race weekend in car footage Reply with quote
Hi All,
Thought I would post some footage of my car at Ruapuna a few weeks back, got a new fastest lap!
Insert URL: https://youtu.be/S-KeSFRL2U4
1982 924 Race Car
1981 931 Road Car
Kenodog
PostPosted: Fri Oct 06, 2017 7:41 am    Post subject: Reply with quote
That is a pretty quick little 924. What powerplant is in it ?
Leigh
1979 Euro 931, Olive
1981 931, Sabine
2014 Mazda CX-5 (Kid's limo)
2008 GS500
1996 Dodge Caravan (DJV)
Robert Hooper
PostPosted: Fri Oct 06, 2017 8:56 am    Post subject: Reply with quote
Car is running the 3L 968 motor, 60mm ITB's, custom cams, running just over 300hp,
The car is very light, its has no glass all perspex and lots of fiberglass, it is a 924 with the engine mounts cut from a 968 to accommodate the engine and gearbox changes.
The limiting factor is i am running a 951 gearbox at the moment, so the gears are too long, 177 in 3rd etc... I am rebuilding a 6 speed at the moment.
The other thing is that i dont run slicks, just toyo R888's and i have no grip, so slipping around a bit,
Cheers Rob
[img][img]
[img]
[/img]
1982 924 Race Car
1981 931 Road Car
KDJones2000
PostPosted: Fri Oct 06, 2017 3:27 pm    Post subject: Reply with quote
I think I'm in love with your engine
Why is your shifter so loose? I would think you are at risk for mis-shifts with as much play side to side that you have in that video.
1987 924S SPEC car
Team Toofah Racing
1988 944 Turbo S
PostPosted: Fri Oct 06, 2017 11:02 pm    Post subject: Reply with quote
Very nice!!!
PostPosted: Sat Oct 07, 2017 12:07 am    Post subject: Reply with quote
Add some chassis stiffening before going on slicks..actually you could do it now too and it would be a good idea
red 924 and not red 924
Robert Hooper
PostPosted: Tue Oct 10, 2017 12:31 pm    Post subject: Reply with quote
"Why is your shifter so loose? I would think you are at risk for mis-shifts with as much play side to side that you have in that video."
I had some real issues with the shifter breaking when i first ran the car, the plastic bit that holds the ball joint at the bottom kept heating up, getting loose and coming out, so i replaced it with a rose joint, this makes the gearstick move around a lot, i hadent noticed it while driving but it looks bad in the video,
Will come up with a fix before the next race!
1982 924 Race Car
1981 931 Road Car
