WTB: A/C control knob for 1978 924 and 931 bellhousing
Goto page Previous  1, 2
PostPosted: Tue Oct 17, 2017 6:31 am    Post subject: Reply with quote
hm, interesting...i never seen the type of system you mentioned above....i have only seen the one on my car and the one you posted...i always thought the one you posted is the aftermarket one but yea...may be early or late...even though my 931 is an S1 and has the "late" knob
red 924 and not red 924
Raceboy
PostPosted: Tue Oct 17, 2017 7:25 am    Post subject: Reply with quote
It has nothing to do with S1 or S2. Only early 1979 931's and 924's had early A/C system, late 1979 and on already had later type.
'83 924 2.5 16v Turbo, 470hp
'78 911 SC 2.5 ss Turbo "Martini"
'82 924S/931 "Gulf" racecar, 330 hp, sold
'84 924, turbocharged, sold.
brian19600
PostPosted: Sun Oct 29, 2017 2:58 am    Post subject: Reply with quote
My '78 with factory air had that knob. The switch is a multi-function vacuum/electrical engineering marvel. The problem with mine was the "freeze sensing" thermocouple that goes to the evaporator was broken off. I'm pretty sure I tossed it, but I will double check.
I updated mine to the later switch, and added an electrically controlled vacuum valve from a toyota. I also got a toyota a/c switch to turn the compressor on. It all works and unless you're an expert in old 924 a/c permutations, it could probably pass for stock.
If you were updating the switch, you would also need an a/c amplifier box and the freeze switch for the evaporator.
Raceboy
PostPosted: Sun Oct 29, 2017 5:51 am    Post subject: Reply with quote
Would be great if you could double check it! Thanks a lot!!!
brian19600
PostPosted: Sat Nov 04, 2017 5:29 am    Post subject: Reply with quote
I looked. Sorry, I had tossed it.
Post new topic   Reply to topic    924Board.org Forum Index -> Cars and Parts Wanted/For Sale All times are GMT + 11 Hours
Page 2 of 2
