Found injectors with long nose suitable for EFI conversion
Raceboy
PostPosted: Mon Oct 02, 2017 4:06 am    Post subject: Found injectors with long nose suitable for EFI conversion Reply with quote
Even though pretty much any injector works with 924/931 when doing an EFI conversion, the nozzle still sits in a sort of tube left from long CIS injector. That harms driveability a bit.
Since I may be converting one 924 n/a to turbo some time in the future I was looking for injector that is bigger than 200cc or so (that most long-nose injector are usually).
Bosch 0 280 158 123 is 590cc, high-impedance and good for quite a bit of power on 924
These are actually OEM injectors for 997 Turbo for example and few others.
'83 924 2.5 16v Turbo, 470hp
'89 944 S2
'91 944 S2
'78 924 Carrera GT project
'78 911 SC 2.5 ss Turbo
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
PostPosted: Mon Oct 02, 2017 4:31 am    Post subject: Reply with quote
Thanks for the info.
red 924 and not red 924
Kenodog
PostPosted: Mon Oct 02, 2017 5:24 am    Post subject: Re: Found injectors with long nose suitable for EFI conversi Reply with quote
Oh good, at least they'll be cheap then..
Leg
1979 Euro 931, Olive
1981 931, Sabine
2014 Mazda CX-5 (Kinderwagon)
2008 GS500
1996 Dodge Caravan (DJV)
Raceboy
PostPosted: Mon Oct 02, 2017 5:36 am    Post subject: Reply with quote
They are usual price, around 50-60 usd/eur for a piece new, depending where you buy.
'89 944 S2
'91 944 S2
3forall
PostPosted: Mon Oct 02, 2017 9:52 am    Post subject: Reply with quote
An easier and cheaper alternative are those from a Volvo with the turbo 1.9. They are 42lb or about 440cc injectors with the long nose. I drilled out some injector cups (don't know what car or injectors they were meant for, but they had the right thread) and the injector sits flush with the bottom of the injector hole. I got 8 at the junkyard for 20$. I then cleaned and flow tested and all was dandy.
http://www.ebay.ca/itm/Reman-Siemens-Deka-Fuel-Injector-6900371-Volvo-1-9L-Turbo-/300975840297
Reman they go for around 40$
1981 924 Weissach edition
1982 931 - Megasquirt and liquid intercooler
1969 911
gegge
PostPosted: Wed Oct 04, 2017 5:11 am    Post subject: Reply with quote
I have the big brother 040 pumping 980cc
Conical spray pattern instead of wide twin beam pattern for multivalve engines.
Carl Fredrik Torkildsen
Raceboy
PostPosted: Wed Oct 04, 2017 5:33 am    Post subject: Reply with quote
Isn't 040 a CNG/LPG injector originally? Any issues?
'89 944 S2
'91 944 S2
PostPosted: Sun Oct 15, 2017 5:21 am    Post subject: Reply with quote
Part number?
Trying to gather parts for vems conversion...those 911 injectors look good and will be 200 eur new for a set...but i'm shopping
gegge
PostPosted: Sun Oct 15, 2017 10:20 pm    Post subject: Reply with quote
E85 compatible 0 280 158 040
Didnīt know they worked with CNG and LPG
