Joined: 05 Jun 2006 Posts: 1362 Location: Ontario, Canada
Posted: Tue Sep 12, 2017 7:16 am Post subject: turbo 4.10 vs 6.10??? |
Did some reading here and I can't find the answer, what is the difference between a 4.10 and 6.10 turbo?
How this difference would translate on the road/car feel/spool/lag/etc..?
Thanks _________________ 1976 924 N/A ROW SOLD
1980 931S
1981 931 Part car RIP |
WEASEL149
Joined: 19 Aug 2005 Posts: 595 Location: UK, Sheffield
Posted: Wed Sep 13, 2017 2:09 am Post subject: Re: turbo 4.10 vs 6.10??? |
924-76 wrote: | Did some reading here and I can't find the answer, what is the difference between a 4.10 and 6.10 turbo?
Thanks |
The number is the turbine housing nozzle/volute size.
The 4.10 is smaller so gives better response at low revs but causes more back pressure at high revs. _________________ 1979 UK 932 |
Posted: Wed Sep 13, 2017 2:20 am Post subject: Re: turbo 4.10 vs 6.10??? |
WEASEL149 wrote: | The number is the turbine housing nozzle/volute size.
The 4.10 is smaller so gives better response at low revs but causes more back pressure at high revs. |
Exactly what I was looking for, thank you _________________ 1976 924 N/A ROW SOLD
1980 931S
emlynbeagler
Joined: 22 Jan 2007 Posts: 9 Location: Llandovery, UK
Posted: Thu Sep 21, 2017 6:48 am Post subject: |
I replaced the 4.10 turbine on my Series 2 931 with a 6.10 from the S1, mated to the later compressor. I recommend doing the same. It spools up a tiny bit later (there's loads of lag anyway), but blows right up to 7000rpm (or what the tacho tells me is 7000rpm) and makes the car much more eager if you keep it spooled up. I have done 12,000 miles since tinkering with the turbo (on an engine that has now done 240,000 miles without a rebuild) and everything seems ok. There is a reason that 0-60 is about half a second slower on a stock S2! _________________ 1984 924 Turbo
2017 Alfa Romeo Giulia Quadrifoglio
2017 Isuzu D-Max
1974 Moto Guzzi 850T |
