Has anyone tried this supercharger kit?
jonnyenglish
PostPosted: Fri Sep 08, 2017 10:25 pm    Post subject: Has anyone tried this supercharger kit? Reply with quote
Just wondering if anyone on here has tried this kit on a 924 S? Im looking at making my own similar to this. My intention is to make a kit using almost universal parts, with a bit of fabrication, to create 200-250ish bhp 924 S
http://speedforceracing.com/product/stage-2-944-supercharger-system/
I would like to put together a list of parts that will be required, from the centrifugal supercharger, intercooler, the silicone hoses, megasquirt etc.
if anyone has any help or advice that would be great!
so far im looking at these.....
Supercharger... http://www.ebay.co.uk/itm/P-2-Centrifugal-Supercharger-Without-Gearbox-/351907501076?hash=item51ef525414:g:FNoAAOSwOuRZsGQ~
ECU... http://www.ebay.co.uk/itm/Emerald-K6-ECU-ELC0275-Kit-Car-Sports-Car-Classic-Car-Race-Car-/253137847115?epid=735360840&hash=item3af031034b:g:yl8AAOSwHnFVjUte
Intercooler and some piping (probs need more than this but will be a start)... http://www.ebay.co.uk/itm/272720256424
different radiator... not sure what would fit someone has suggested a civic type R rad??
then theres all the parts from the kit at the top on top of that so for £1500-2000 i cant see why it couldnt be done relatively easily and relatively cheapily! apart from mounting brackets and putting it into place im not sure what else would be required?
Thanks for any help and advice.... Oh and im not interested in an engine change want to keep the original engine, also I have the 160BHP version... not sure that makes a difference or not??
Thanks!
Jon
Raceboy
PostPosted: Sun Sep 10, 2017 6:09 am    Post subject: Reply with quote
If you want to save time and effort in the engine control department, I can offer VEMS Plug and Play engine management for your 924 S. Plugs right into factory DME connector and works on the stock sensors (also has onboard WBO2, sensor is included in the kit).
Has German TÜV certificate too.
'83 924 2.5 16v Turbo, 470hp
'67 911 Irish Green hotrod, 2.4S
'89 944 S2
'91 944 S2
'78 924 Carrera GT project
'78 911 SC 2.5 ss Turbo
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
Paulyy
PostPosted: Mon Sep 11, 2017 12:49 pm    Post subject: Reply with quote
You should most definitely have a small webshop! Use a site like Word Press. Even if it's for 3 items
Edit: Nevermind, you do have one.
924 - Race car project in the works.
http://www.924board.org/viewtopic.php?p=384410#384410
951 - 400whp.
PostPosted: Mon Sep 11, 2017 6:04 pm    Post subject: Reply with quote
I like the idea of that supercharger however I don't like the price.
red 924 and not red 924
jonnyenglish
PostPosted: Mon Sep 11, 2017 10:05 pm    Post subject: Reply with quote
I hear ya mate, that's why i want to have a go a creating my own kit. i reckon i could do it for around £1500 if i can get the parts, which all being well could provide 60+bhp depending on the mount of boost... getting it fitted and mounted would be easy, making it work is where i would struggle so would need the advice and help of others.... but i think it could potentially be what i will try in the new year.... get the old girl ready for it over winter then whack the supercharger on for next summer.
Working out how to get it to run will be the hard part, I'm not even 100% sure what i will need for the kit. Will have to do some research!
jonnyenglish
PostPosted: Mon Sep 11, 2017 10:07 pm    Post subject: Reply with quote
this looks interesting, how much would it be delivered? Also will it work with a supercharger, obviously would need it to control the amount of fuel and air etc. and make the charger work efficiently. Does it have this capability?
Raceboy
PostPosted: Tue Sep 12, 2017 6:06 pm    Post subject: Reply with quote
Of course it can cope with supercharger. It is a full standalone engine management, you can throw ANY engine mod you like to it.
BTW, I just finished a VEMS PnP kit for 944 n/a that will get Eaton M90, car is built in Iceland.
Here's Rennlist thread of the car: https://rennlist.com/forums/924-931-944-951-968-forum/1008626-supercharging-a-1985-944-n-a-positive-feedback-only.html
'89 944 S2
'91 944 S2
WEASEL149
PostPosted: Tue Sep 12, 2017 8:42 pm    Post subject: Reply with quote
Jonnyenglish, if you decide on going VEMS you won't find anyone better than Raceboy to deal with. He has years of experience with it.
This applies even more if you have limited stand-alone ECU experience as he can tailor it to your needs and give you advice.
1979 UK 932
jonnyenglish
PostPosted: Tue Sep 12, 2017 10:37 pm    Post subject: Reply with quote
This all sounds perfect! so essentially, i build the supercharger system... then this plug and play device goes on and raceboy creates a map to suite it? Will it include all the necessary sensors for the conversion? i.e. fuel air, tempreture sensors etc. also will it require a maf sensor conversion or is the standard 924 S one ok??
It's the electronic side that has my melon twisted. but if its as simple as this then to me it seems a no brainer!!!!
exciting times..... this is what i am planning on using for the conversion.
1x Centrifugal Supercharger (i like the idea of this for its ease and simplicity)
1x VEMS Plug and Play ECU
1x Front mount intercooler + Ducting
1x Dump/recirculating valve + Piping
4x 944 turbo injectors
1x Larger/More efficient radiator
Anything else?
Raceboy
PostPosted: Wed Sep 13, 2017 2:20 pm    Post subject: Reply with quote
Thanks
It runs mostly on stock sensors and few more that are needed are included (throttle sensor, wideband and air temp). VEMS has built in MAP sensor.
Just plug it in, install sensors and turn the key. You will need to fine tune the fuel table probaböy but that it very easy to do, just check the tutorial here: https://www.youtube.com/watch?v=U7fyfhY_FhI&t=1s
And I am available for help also. Check my FB page www.facebook.com/vemsporsche
'89 944 S2
'91 944 S2
jonnyenglish
PostPosted: Wed Sep 13, 2017 11:02 pm    Post subject: Reply with quote
This my friend sounds perfect, how much is VEMS? and how can i go about ordering? this will for sure be the first purchase for my project!
Raceboy
PostPosted: Fri Sep 15, 2017 7:28 pm    Post subject: Reply with quote
VEMS Plug and Play kit is 1250 euros shipped to you, includes VEMS ECU w/ Bluetooth, harness adapter (or straight Motronic VEMS, your choice), Bosch LSu4 wideband sensor, air temp sensor+adapter cable to connect tp AFM plug, throttle sensor+6pin->3pin adapter cable and well running tune.
With the kit everything is bolt on except perhaps lambda bung if your car was not equipped with lambda sensor. I can include M18x1.5 threaded bung for it to be welded.
You can order by emailing me peep@vems.ee
'89 944 S2
'91 944 S2
