Joined: 23 Jul 2007 Posts: 1076 Location: The Netherlands
Posted: Sat Jun 23, 2018 5:09 am Post subject: Is there a 931 S2 ignition distributor replacement ? |
Th distributor look like a normal distrubor where the inside had been removed.
Can you use a 924 na (or other car)ndistrributor, empty it, and use for a 931 ? _________________ 937 trackday car
Johann
Posted: Fri Jul 06, 2018 12:40 am Post subject: |
Yes, that should work without a problem. |
