Found me a Weissach
Goldwolf
PostPosted: Thu Apr 11, 2019 4:25 am    Post subject: Reply with quote
Mains delivered to the engine builder. Clutch has been ordered. Hopefully I get this thing back before Summer.
Then I get to see what else is broken. Which I don't think is too much really. The power mirrors still worked.
1981 Weissach Edition #179
Savethe924.com
Goldwolf
PostPosted: Tue Jul 30, 2019 9:49 am    Post subject: Reply with quote
Engine pics
Savethe924.com
PostPosted: Tue Jul 30, 2019 11:36 am    Post subject: Reply with quote
Nice progress! Gonna be clean!
Goldwolf
PostPosted: Tue Aug 06, 2019 3:21 am    Post subject: Reply with quote
Updates and links
Rear seat belts. I just want to install the manual 3 point belts. Doing some research.
http://924board.org/viewtopic.php?p=398348#398348
Distributor pickup, bought the Standard Motor one, has the 3 prongs needed for an 81.
http://924board.org/viewtopic.php?t=44264
A/C compressor
I bought the model TCW 30040.101 from autocompressorworld.com it is only listed under the 924 Turbo, hopefully it will fit. This is one includes the clutch. The FOUR SEASONS 57320 seems to be readily available, but does not come with the clutch.
Also bought the fuel tank strainer and a new fuel sending unit from Porsche in Atlanta, it was cheaper there!
Savethe924.com
Goldwolf
PostPosted: Thu Aug 08, 2019 2:37 am    Post subject: Reply with quote
I have now ordered 2 compressors, one was out of stock, the reman unit, the other from Ebay did not test good before being shipped, glad they tested it.
Still looking.
Savethe924.com
PostPosted: Thu Aug 08, 2019 3:58 am    Post subject: Reply with quote
Goldwolf wrote:
Still looking.
I have an AC compressor I took off my 80 931 just sitting..
I never even tried my AC before I removed it so I have no idea if it's any good or not, but it has been sitting safely inside this whole time so it isn't ruined I don't think..
You want it?
Goldwolf
PostPosted: Thu Aug 08, 2019 5:59 am    Post subject: Reply with quote
Sent you a pm.
I just bought this one
https://www.ebay.com/itm/351437378326
Looks like the same unit Griffiths sells for the 930, which is the same as the lowly 924.
I'll see if this one is works.
Also, found this company that will rebuild them for $180, in Van Nuys
http://www.compressor-intl.com/HTML/Por81.htm
Savethe924.com
Goldwolf
PostPosted: Fri Aug 09, 2019 4:06 am    Post subject: Reply with quote
Strike 3 on the Ebay one, out of stock, but they showed 4 available. Sending to get rebuilt.
Savethe924.com
jacobroufa
PostPosted: Fri Aug 16, 2019 12:02 am    Post subject: Reply with quote
@Goldwolf -- I posted in the seat belt thread a link to a 3pt retrofit belt from CIP1 (a primarily air-cooled VW supplier) as it might be appropriate. I am also interested in doing a 3pt conversion in my Weissach, so I might pick up a single belt to try when I get some time...
1980 Porsche 931
1981 Porsche 924 Weissach
Goldwolf
PostPosted: Fri Aug 16, 2019 4:52 am    Post subject: Reply with quote
Yes thank you!
I also found these from some of the other seat belt threads
https://www.ebay.com/itm/SECURON-Seat-Belt-Static-Lap-Diagonal-Black-200/302043451160
They seem appropriate, I don't want the retractable ones, I think the mounting may be a pain. It seems like the manual 3 point mount points were in every car just not used in the US.
Also, sent my compressor to compressor international, I ordered it 4 times from various places, all were out of stock
Savethe924.com
Goldwolf
PostPosted: Wed Aug 28, 2019 4:40 am    Post subject: Reply with quote
My saga continues.
Got the A/C compressor back from Compressor Intl, they turned it around in about a day. $180 plus shipping both ways. Looks good so far.
The distributor pickup I ordered turned out to have the wrong connector, we think it is Intermotor part#LX596 that works for a 86 Jetta.
The rest of it matched exactly. Of course it was rebuilt into the distributor so had to order the female plug(443-906-236) from VW, should be here tomorrow. Hopefully this will work.
That is the last piece to get this thing running. The connectors on this pickup are blades, I need a backup connector, anyone know of a squeeze type that would work?
The original plug is NLA, so maybe this is another workaround, although you could just use the spade terminals on the old pickup. I don't know the Porsche part, but this is the VW part.
Still on my car
The VW part
This obscure post Club 80-90 helped me out
Savethe924.com
Goldwolf
PostPosted: Wed Aug 28, 2019 5:10 am    Post subject: Reply with quote
Just stumbled on this, I guess you can make your own connector.
https://www.brickwerks.co.uk/wiring-terminal-junior-timer-5mm-to-2mm.html
Savethe924.com
Goldwolf
PostPosted: Fri Sep 06, 2019 11:19 pm    Post subject: Reply with quote
The VW connector and wires from VW worked and the car is running!
Some final tuning to be done, and charging of the AC. I ordered the bushing for the throttle cable (823721567) as it is popping off.
I don't like the blue wires.
This has been its home for the past 2 years, I think its coming home next week. 944's and 911's have kept it company. I am getting the windshield replaced first.
Savethe924.com
Goldwolf
PostPosted: Fri Sep 20, 2019 5:06 am    Post subject: almost home Reply with quote
I think it will be done this afternoon, time to pay the piper. 1987 930 hiding back there behind the 4s
Savethe924.com
Goldwolf
PostPosted: Sat Sep 28, 2019 4:35 am    Post subject: Reply with quote
Drove the damn thing home Wednesday. A/C works! All the electrics seem to work. More to come, need to fix the sunroof brackets and seal. Already have the seals. No longer (under repair)!
Savethe924.com
Page 3 of 5
