washer fluid
Jesus
PostPosted: Fri Sep 13, 2002 7:52 am    Post subject: Reply with quote
My pump for washer fluid does not work. Do anyone know something about that?
PostPosted: Fri Sep 13, 2002 11:38 am    Post subject: Reply with quote
The lines often get clogged with algae; clean thoroughly. The pump motor could be bad or more likely not getting power. Check at the pump motor connection for power first, using a voltmeter or test light, then go from there.
