Urgent help!! alternator wont charge
Paulyy
PostPosted: Sat Jul 29, 2017 1:40 am    Post subject: Urgent help!! alternator wont charge Reply with quote
Ive been tackling some back yard job wiring on this car. The starter wring was arcing out causing all sorts of issues.
We've re done it. But now the alternator wont charge. The battery light wont turn on. But there's 12v coming from the 3pin plug that goes to the alternator. i've tested the wires, and ran new ones. Ive changed alternators to a known good one and no charge.
It's wired correctly as i went by the schematics.
Any help appreciated
I need to get this car driving tomorrow as its booked in for a road worthy and running out of time.
924 - Race car project in the works.
http://www.924board.org/viewtopic.php?p=384410#384410
951 - 400whp.
Kenodog
PostPosted: Sat Jul 29, 2017 1:44 am    Post subject: Reply with quote
Silly question but is it grounded correctly ? If it is and still not charging then try to run a direct cable from the alt to the battery and by-pass the starter.
Leigh
1979 Euro 931, Olive
1981 931, Sabine
2014 Mazda CX-5 (Kid's limo)
2008 GS500
1996 Dodge Caravan (DJV)
Paulyy
PostPosted: Sat Jul 29, 2017 1:53 am    Post subject: Reply with quote
Leigh
Yes its grounded, the car starts ect no problem there.
The battery connects to the starter and the starter goes to the alternator and there's power at the big and little cable on the alternator.
951 - 400whp.
Paulyy
PostPosted: Sat Jul 29, 2017 2:03 am    Post subject: Reply with quote
i pulled the cluster out and battery light works too
951 - 400whp.
Paulyy
PostPosted: Sat Jul 29, 2017 4:49 am    Post subject: Reply with quote
Ok finally fixed it.
after 4 hours of trying and testing. I had everything wired up correctly, and i'd turn the ignition on and id hear relays clicking, and the dash would dim.
i thought i must be on the right track weirdly.
So i unplugged 2 of the 3 wires from the 3 pin plug that goes to the starter. (i cut the plug off and use spades as the wires where about to fall off the crimps)
Started the car. plugged them back in and it worked.
I don't even know what the initial problem was. Im suspecting grounding.
951 - 400whp.
