check valve vacuum 931 S2 ?
PostPosted: Fri Jul 21, 2017 4:26 pm    Post subject: check valve vacuum 931 S2 ? Reply with quote
Does a 931 S2 (ROW) have a check valve in the vacuum lines? (except for the one in the brake booster)
If yes, where should it be ?
937 DITC
PostPosted: Fri Jul 21, 2017 6:17 pm    Post subject: Reply with quote
As far as I know only the S1 has this.
red 924 and not red 924
PostPosted: Fri Jul 21, 2017 7:12 pm    Post subject: Reply with quote
Correct. Only the S1 has vacuum/retard via the distributor and the red/white check valve is required to manage the pressures.
