Horn doesn't work
Lilracerdude
PostPosted: Fri Jul 21, 2017 7:40 am    Post subject: Horn doesn't work Reply with quote
Hi, I've come across a problem my horn just stopped working. I poped off the center button and the cable is connected. Then I checked the fuse and made shure it wasn't corroded. But when I used a volt meter to see if there is power to the fuse I got none. Could anybody help?[/img]
Harm
PostPosted: Fri Aug 11, 2017 7:41 am    Post subject: Re: Horn doesn't work Reply with quote
The steering rack assembly is supposed to make good ground. Strap an extra ground wire between/around shaft and chassis on the inside, underneath the dash that won't block your steering.
http://www.924board.org/viewtopic.php?t=39103
dual turbos
PostPosted: Sun Nov 26, 2017 1:31 am    Post subject: Reply with quote
I'm working on the same problem, I cleaned off the contact points under the padded steering wheel cover and the contacts on the steering wheel itself. I pulled the steering wheel off the car and discovered that the copper ring on the steering wheel was greasy and not a clean connection, also the copper spring tab that connects to the copper ring was worn. I did not fix my horn yet, but I'am still digging. I have pictures of the steering and the connector, but I don't know how to post pictures on this site.
Dual Turbos
PostPosted: Sun Nov 26, 2017 7:05 am    Post subject: Reply with quote
Make sure the horn works by giving it 12 volts....
