Need help with 931 engine problems
PostPosted: Mon May 15, 2017 4:15 am    Post subject: Need help with 931 engine problems Reply with quote
I have a/ some problems with the 931 series 2
When cold: running rough at idle/ low rpm
When warm:
Running nicely, great power
But running lean at cruise(AFR 17-20) and under boost (+/- 14)
Vacuum reading is 13/14 – the vacuum gauge says problem with timing
I checked the timing with a stoboscoop and I can see the ‘dot’ on the flywheel which seems to be good.
The enige is fully rebuild.
Modifications:
951 turbo s and intercooler
Stage 1 camshaft
Forge boost controller
Forge recirculation valve
937 DITC
What direction should I be looking for ?
937 DITC
924-76
PostPosted: Mon May 15, 2017 4:25 am    Post subject: Reply with quote
Have you perform a smoke test for vacuum leak?
What is your AFR at idle?
Vacuum gauge should read around 17 at idle.
1976 924 N/A ROW SOLD
1980 931S
1981 931 Part car RIP
gegge
PostPosted: Mon May 15, 2017 4:39 am    Post subject: Reply with quote
Check CIS pressures, guessing the WUR.
Carl Fredrik Torkildsen
924 turbo -81 Carrera GT clone LSD Coilovers
924s -86 Black on black with low ET "Phonies"
PostPosted: Mon May 15, 2017 4:46 am    Post subject: Reply with quote
WUR
Check the CIS pressures.
Check if injectors are working right.
Check if fuel pump is getting 20 Amps.
red 924 and not red 924
PostPosted: Mon May 15, 2017 4:47 am    Post subject: Reply with quote
AFR at idle is 14.5-15.
I haven't checked the fuel pressure yet. Will do that next week.
Injectors are new
What do you mean with check the fuel pump is getting 20amp ?
937 DITC
PostPosted: Mon May 15, 2017 5:21 am    Post subject: Reply with quote
just pulled out the spark plugs, the all look black, so they don't look like it is runnign lean
937 DITC
PostPosted: Mon May 15, 2017 5:47 am    Post subject: Reply with quote
Can you swap out the AFR sensor and gauge to rule out readout error?
PostPosted: Mon May 15, 2017 5:58 am    Post subject: Reply with quote
recalibrate your wideband sensor and gauge.
PostPosted: Mon Jun 05, 2017 5:49 am    Post subject: Reply with quote
Checked the fuel pressure today with a running engine:
Pump pressure: 6,2 bar (should be between 5,8-6,5) ok
Cold pressure: 1,5 bar (should be between 2,4- 2,8 ) not ok
Warm pressure: 2.0 bar (should be between 3,45-3,85) not ok
Does this means my WUR has not died ?? I haven't checked if it gets 12v yet.
937 DITC
PostPosted: Sat Jul 01, 2017 1:28 am    Post subject: Reply with quote
problem solved, the wur was bad, replaced it and all pressures are good now.
AFR is also good at cruise now
937 DITC
