1979 924 - pickup wire at distributor
Denvic
PostPosted: Fri Jun 30, 2017 12:03 am    Post subject: 1979 924 - pickup wire at distributor Reply with quote
I have no spark and during troubleshooting discovered an intermittent connection at the distributor where the cable from the transistorized ignition box hooks up. The cable appears to be a shielded single conductor that goes into a molded connector. I've had no luck finding a replacement cable and connector, so I may have to do something creative. Can anyone suggest a source for a replacement cable and connector, or failing that, a work around?
Thanks
KDJones2000
PostPosted: Fri Jun 30, 2017 3:22 am    Post subject: Reply with quote
Very careful soldering fixed mine...
1987 924S SPEC car
Team Toofah Racing
1988 944 Turbo S
