Wur fuel lines in/ out ?
PostPosted: Wed Jun 21, 2017 12:24 am    Post subject: Wur fuel lines in/ out ? Reply with quote
The 931 wur has got a large and a small connection, does the line from the top of the fuel distributor (out to WUR on teh second picture) go to A or B ?
937 DITC
PostPosted: Wed Jun 21, 2017 12:55 am    Post subject: Reply with quote
One of the banjo fittings is smaller, so you should only be able to plumb it one way.
PostPosted: Wed Jun 21, 2017 3:35 am    Post subject: Reply with quote
I know, A is the bigger one, but they modified the lines on my car and made a split connection with the same connection at both ends.
I asume A is is the one connected to the top of the distributor because it is bigger and had a filter.
937 DITC
