lower radiator mounts damaged?
procyon
PostPosted: Wed Jun 14, 2017 1:29 pm    Post subject: lower radiator mounts damaged? Reply with quote
I am reinstalling the rad in my '80 NA and there is a problem with the lower two rad mounts on the lower valence.
I am fairly sure that 14 months ago i removed M6 bolts that fastened the rad to the body, but now there is nothing to thread the M6 bolt into. There is a slotted bracket there for the rad and the skid plate. The bracket looks like it would hold a captive nut but there is nothing in there nor does there seem to be a way to get a nut in there.
The parts catalog says a M6 bolt is used but there is no mention of a nut.
So have I lost a couple of parts or am I just stunned and missing something obvious?
1980 924 N/A ( 5 bolt discs and better paint)
2007 Subaru Forester
2007 Toyota Camry
Ian89C4
PostPosted: Thu Jun 15, 2017 2:39 am    Post subject: Reply with quote
There should be two capture nuts for the lower radiator mounting point. The crimps that hold them in place were probably widened and the nuts fell out (I hate it when that happens ). You should be able to get an m6 nut back in there though.
Cheers,
Ian Edgerly
Spiveys Corner, North Carolina
Current:
1981 924 Weissach Race Car ("Serenity")
1980ish 931 ("Alice")
procyon
PostPosted: Thu Jun 15, 2017 10:23 am    Post subject: Reply with quote
Yeah thats kinda what I thought happened. I'll see what I can jam in there tonight. Otherwise we are on to Plan B.
2007 Toyota Camry
